1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 92 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 92 | Good Morning. I bought and started working on '48 Chevy 2-ton flatbed about a month ago. Thanks for having this site as it's provided alot of usefull and inspirational information. Somewhere along the line someone put a '56 235 in the truck and my question is this. Since truck engines sit relatively level was there a stock intake manifold that did not have the elevation offset in it so that the carb sat level too?? Thanks for all your help.
1948 Chevy 6400 1964 Chevy 1/2 Ton
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Welcome to the list! I'm not real sure I know what your asking...to the best of my knowledge the car and truck motors all sit at almost the exact same angle, slightly lower in the rear, not level. Mike B  | | | | | Joined: Dec 2006 Posts: 92 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 92 | Hi Mike, thanks for the reply. I see what you are saying, but my engine sits pretty level to where the carb is tipped forward. Maybe the engine mounts on the front need shimmed up. I don't think it hurts anything... I was mostly curious, plus the air cleaner would look nicer if it was level. Thanks.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a 56 235 mounts differently than a 48 ... whoever put the engine in may not have rigged the front mounts properly
Bill | | | | | Joined: Dec 2006 Posts: 92 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 92 | Thanks for the reply Bill. I'll look at it more closely to see what was done. Maybe I can shim it up to where it should be.
