5 members (1955 1 Series, Jims46, Otto Skorzeny, Gray_Ghost, dt235sd), 132 guests, and 1 robot.
Topics128,191
Posts1,057,365
Members48,469
V
V Offline
Looking for advice on which motor support mtg on 51 3100 using TCI x-member LS1 Gen III engine ? Thks!
I am having trouble finding a TCI engine crossmember. Do you have a part number or link for the one you are looking at?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
V
V Offline
I got the Total Cost Involved coil spring crossmember but if I did another one I might consider the coil-over one. Part number for coil spring one is 232-2354-00 I believe is correct. If I were flush with $$ I would be tempted to get the frame option..LOL My LS1 Gen III engine is about 1 to 1 1/2 inch forward of the stock fire wall. I'm a little tight on clearance on the frt to rad but it should work.
Ok, I am more confused now.
What is your question? That part number comes up as an IFS conversion, not an engine crossmember.
This part?
If your engine is 1"-1.5" from the firewall, then you already have motor mounts positioning it there?
Or are you saying that is where you want it and you are looking for an engine mount solution?
My 1934 Chevy Master 5W coupe has this engine and as I recall it was a snap to fab up engine mounts. Used home made block/frame brackets and flat head Ford biscuit type mount cushions. About a half hours work. I made templates for plasma cutting out future brackets.
Evan
V
V Offline
Yep it's just on chain hanging there...that's where it's going. I found some adjustable mounts on Holley web site looks neat. My steering rack will have to have the mount forward for my steering shaft and joints to clear.
V
V Offline
Using TCI xmember my eng mount has to be as forward as possible to be able to clear steering linkage needed on my 51.
I am still not clear what you are asking.
Do you want a recommendation for an engine crossmember?
V
V Offline
No got that...motor mounts suggestions...
So what engine crossmember did you get? That will drive what kind of mounts you need.
If you are wanting to use the IFS conversion as an engine crossmember as well, then the first thing to check is if it lines up with where your engine mounts need to be.
V
V Offline
Looks like the Holley adjust mounts will work. Trying those...so far so good...
