1 members (baldeagle),
91
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | At long last, I have my 52 Chevrolet 2 ton up and running. It feels great to be behind the wheel of one of these beautiful old behemouths. But..... When I first drove a 52 2 ton, more years ago than I want to think about, that truck- a reefer, ran along nicely at 50-55 mph. My present truck, also a 2 ton, also a 235 with a 4 speed/2 speed axle is straining at the gills doing 35-38 mph, and this is in 4th gear high range. It almost feels as though there must be a 5th gear somewhere, but nowhere in the gear train can I find another notch. Did Chevrolet build some of theres with a super low speed rear end, even with a 2 speed; or is there another solution? I'm stumped! Sam the Meat Man 1952 Chevrolet 2 ton
sam
| | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | I'm a rookie, but that sounds unlikely that a truck wouldn't be capable of speeds greater than that. Are the wheels stock height? If so then I would re-think the 2speed hi, maybe somehow you are still in low? | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | It may be back years ago you were more interested in making time and not as concerned about possible overreving. Now your concern is possible damage to truck. Congradulations on getting it running. My cousin has a GMC that reuputedly has Hyway gearing. don't know what ratio that would be. Had a 48 1 ton that would easily run 60mph I had no concerns about blowing it up at the time. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Originally posted by kb3csw: It may be back years ago you were more interested in making time and not as concerned about possible overreving. Now your concern is possible damage to truck. :DThat's exactly what I was thinking! The truck's no longer to make money, now the goal is preservation.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | From what I have been able to understand, so far, my truck has a low speed rear end, and was specifically designed for farm work. My options are yo leave it like it is, and take forever to get around, or to put a higher speed rear end in it. An old time mechanic confirmed what kb3csw had noted, there were indeed rear ends that allowed 50+mph speeds. What would another rear end cost, and where might I find one? Sam 52 Chevrolet 2 ton
sam
| | | | | Joined: Oct 2006 Posts: 39 Junior Member | | Junior Member Joined: Oct 2006 Posts: 39 | Hi Sam. I just picked up a 53 2 ton and although I really haven't run it on the highway, it does run down the road at 50 or so with no real strain. From the way it sounds at that speed, it should "Cruise" at 55 or 60 with no problem. Granted, it's not like a car, but I expected it to be a bit noisy at speed. I would agree that it sounds like you are still in low range, but no expert here....That's just how mine sounds when in low at those speeds... | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | SamTTM couldn't find turbotville on the map but there are still a few pull your own parts yards in Pa. one comes to mind up at Hazleton and another just off the NE extentsion near Jim Thorpe. cost I have no idea or whether they would have any big bolts. Are you certain the 2 speed portion is working properly?there should be a noticable change in the rpm when you go from low to high | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Is it possible there is a factory govenor on it? | | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | My 1st thought was also that I was in low range, but I can definately feel the shift as I go from low to high, and can also note the rpm change. I have even been a bit creative and tried some split shifting (using the transmission and 2 speed in combination shifting). The thought of a governor had occured to me, so I will check that out. KB3csw, I am sure you are thinking of Harry's U-Pull-It; the place isn't all that far from me, and I even know a guy who used to work there, so that is a good lead. Rick, thanks for the affirmation. Although it has been almost 40 years since I drove that old reefer, I knew she did better than my present 35-38 mph. Sam 52 Chevrolet 2 ton (Schuyler)
sam
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Yes harry's is it went by there today. It looks like they are cleaning up the one down by Jimthorpe. They had a B model Mack wrecker there that was always calling. | | |
