Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#149297 11/29/2006 1:31 PM
Does anybody have a diagrahm or schematic of the inside of a steering column Mine disintegrated. I have the new bearing that is incased in the plastic with the wire attached. The plastic case was missing. The p.o. had the horn on a horn button taped to the steering column. Thanks in advance. Lou. H.
#149298 11/29/2006 3:50 PM
nothing fancy enough for a diagram Lou, just take off the wheel, get the old bearing out, poke the wire of the new one down the column and out the hole on the side of the column housing sleeve near the dash, push the new bearing into position, wheel back on - if you have the parts for the horn button/cap, put those pieces on and yer honkin
