6 members (Greg '46, Hotrod Lincoln, Phak1, Otto Skorzeny, 2 invisible), 234 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
#1492241 03/15/2023 1:42 PM
I believe that these may be an oil filter? There is a single line running from the block to the bottom of this cannister but the single other line that comes out is blocked off? I tried to remove the top bolt but could not take the top of the cannister off. ????
CBall,
Yes, that is an oil filter common to our trucks.
However, a blocked off line (you didn't say which line is blocked) makes this non-functional.
Could be the blocked line (port?) was blocked because the line between the filter and engine failed???
More pictures of the existing line, drivers side of the engine block in oil line vicinity and blocked line/port would be helpful.
Next step for this conversation is probably to move it to the The Engine Shop for further discussion.
Dan
~ Dan
1951 Chevy 3 window 3100
I will take another photo of the blocked line out of the top, but that is possible. The line from the block to the bottom of the oil can looks newish, so where does the other line that comes out of the top go to?
Authorized Pest
Authorized Pest
As suggested by Gdads51, gonna move this discussion to the Engine Shop. Will get better discussion there.
~ Peggy M
1949 Chevrolet 3804
CBall,
While you wait for others to provide input on your question, check out this existing tech tip on Oil Filters.
Some really great info directly on your topic.
Dan
~ Dan
H Online: Content
The lid has a habit of sticking to the gasket under it. Loosen the center bolt and give the rim of the lid a few gentle taps with a hammer. It's spring loaded, so don't remove the bolt all the way until it comes unstuck. A new filter element will come with a replacement gasket, and it requires a pretty firm torque on the center bolt to prevent leaks when you install the new filter cartridge. Flex lines for a grease gun work well instead of buying somebody's outrageously expensive "original equipment replacement" lines.
Cball,
It should look something like this.
Usually a brass fitting , small line goes to oil pressure gauge in dash.
1950 Chevy 3100
This will help you route the lines. The line connected toward the rear of the block is the pressure line (inlet to the filter.) The one toward the center of the block is a drain port back to the crankcase. There's a metering port toward the top of the standpipe inside the filter canister that keeps the whole thing from draining down.
It sounds like the supply line to your filter has been blocked. It connects at the same place where your oil pressure gauge is tapped in, using a tee fitting.
OIL FILTER INSTALLATION GUIDE
Thank you all for the information. Please take a look at another photo I took of the engine bay. Looks like the previous owners return line broke and they just blocked it off.
AD Addict & Tinkerer
That actually looks like the supply line. Take a look at Kevin’s installation instructions and you can confirm.
Phil
Project Journals
Stovebolt Gallery Forum
CBall,
Just a note to help clarify the info.
The line that is broken at top side of the filter canister is the "inlet" or "feed-line" which was connected to the T-fitting where your existing oil pressure gauge line is connected (towards the rear of the engine and visible in your picture with what looks like a yellow hex nut plug).
The "return" line is the one connected to the bottom of the filter housing and then connected to the further forward oil port on the engine side (located directly behind the exhaust pipe).
Dan
~ Dan
Ah, understood. I will get these two line connected. Thank you all for the help.
H Online: Content
Change both lines. A broken or leaky flex line will empty the crankcase in a matter of minutes, and unless the oil happens to be spraying on the exhaust pipe, creating clouds of stinky smoke, you won't know it until the oil pressure drops and the rods start knocking. Those lines get as hard as woodpecker lips and very brittle with age.
