BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,780 Posts1,039,291 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Nov 2006 Posts: 4 New Guy | New Guy Joined: Nov 2006 Posts: 4 | Restoring a 1954 Chevrolet 6400 and need some wheels. It came with 3 piece 20" but I'd like to go to one piece so that I can put radials on it. Anyone know a source or have any ideas? | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | 'Bolter Joined: Dec 2003 Posts: 1,144 | There are vendors that will make wheels but it's expensive. Some of the modern 19.5 10 bolt wheels off motorhomes, heavy duty chevy 1 tons will bolt up but the center hole may not be as small. You also will lose road speed as the 19'5 are considerably shorter.
You can mount tube type radials on the wheels you have just clean them up and make sure they are sound. I'm currently mounting 8.25 X 20 yokohama tube type radials on mine.
This question has come up a few times thus far I don't think anyone has come up with any new direct replacement wheel. Good luck and welcome to the stovebolt page. | | | | Joined: Nov 2006 Posts: 4 New Guy | New Guy Joined: Nov 2006 Posts: 4 | I can make sure I have sound wheels with the ones I have and others that I can find. Thanks for the advice on the Yokohama tube type radials. Have you had any trouble finding people that would mount tires on the 3 piece wheels. It is my understanding that they are even illegal in some states. Thanks again for the help. | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | Shop Shark Joined: Jan 2005 Posts: 1,602 | I've got the radial 8.25 X 20 Yoko's also and they are not a problem. As for repairs, visit one of the "older" tire shops. I've found them to be experianced and willing to work on the three piece rims without hesitation. Welcome! | | | | Joined: Dec 2002 Posts: 2,538 'Bolter | 'Bolter Joined: Dec 2002 Posts: 2,538 | Welcome to the Stovebolt Page Jim. I'm in Burlington, N.C. Got any pictures of your '54. See my trucks, in the link below. | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | 'Bolter Joined: Dec 2003 Posts: 1,144 | I think the 3 piece rims are legal it is the split wheels that are out lawed. If you can get a 54 truck shop manuel it shows the 2 different types of wheels. | | | | Joined: Sep 2006 Posts: 38 Junior Member | Junior Member Joined: Sep 2006 Posts: 38 | Hey Jim, From my understanding, any two or three piece wheel is considered a split rim. I just replaced all six tires on my '48 6400. The split rims are not illegal here. I had mine done at a big truck and heavy equipment tire supplier....T&W Tire. A lot of shops have gotten away from doing them because they are very labor intensive, plus they can be dangerous if not mounted up correctly. I don't know whats in your area, but check out the major suppliers like the one I mentioned above and also don't forget about the rural shops that do farm equipment. A LOT of pre-1988 farm trucks with 20" wheels are on the job. They have to have their tire work done somwhere.
Another thing Jim....If you do search out some rims Make sure of the rim width, because if you wind up with rims off of a 4400 truck and try to mount up some 8.50 or 9.00 series tires, they don't like to go on. Espesially the 9:00 tires. You cant get the split rim back together.
I have 9.00x20 tires on my 6400 and they just fit the rims, and they really fill up the front wheel wells. I got a very good deal on them, $800 with flaps and tubes & mounted. They were almost new take offs, still had the little rubber spikes on them. They don't rub the fenders but 8.25 or 8.50 tires would have been a little better fit, but new they would have been around $1200
Snapoff brand tools .................................. 1948 Chevy 6400 1949 Chevy 4400 (parts truck)
| | | | Joined: Nov 2006 Posts: 4 New Guy | New Guy Joined: Nov 2006 Posts: 4 | Wow, I've learned more in 24 hours on the stovebolt website than in a year doing research on my own. Thanks to Lee in the library at ATHS for the referral and thanks to all the stovebolters with their advice. Spanky, I've heard about your collection for some time and hope to get over there to see it. My folks live in Lynchburg, VA, and I'll stop by on my way up there. I don't have the fenders or hood done yet but will try to get some "in progress" photos up soon. Thanks again everybody. | | | | Joined: Dec 2014 Posts: 3 New Guy | New Guy Joined: Dec 2014 Posts: 3 | hi my name is Gil i just subscribe to the forum and i wanted to ask anyone if they new where i could get a set of rear wheels for my 54 chevy 1.5 ton out side wheels i think they are 10 bolt pattern they are missing on my truck plus i need a transmission for it the man that sold it to me said the motor is from 1961. Can any 4 speed tranny work. thanks guys for all your help. | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | Shop Shark Joined: Nov 2006 Posts: 2,544 | You'll have better luck if you go down to the "Parts Wanted Section". Your truck would use a SM420 transmission. | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Where did you buy the 8.25 X 20 yokohama tube type radials? Do they have a website?
Where did you buy the 9.00x20 tires on your 6400? Do they have a website?
| | | | Joined: Dec 2014 Posts: 3 New Guy | New Guy Joined: Dec 2014 Posts: 3 | Do you want to sell the wheels from your 54 chevy. | | | | Joined: Sep 2006 Posts: 1,972 Big Bolt Forum Co-moderator | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,972 | I had a heck of a time finding wheels for my 1948. I had taken my wheels with tires on them to Les Schwabs in Washington because I couldn't find anyone in my area that would work on them. They were the split rim. They hammered on them and finally got one apart, but they were too rusty to use. I ended up getting one piece rims made by Stockton Wheel in California and putting on radials. The tire height turned out to be pretty darn close to the originals. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | Joined: Jan 2008 Posts: 4,903 'Bolter | 'Bolter Joined: Jan 2008 Posts: 4,903 | Tim, I've got a pair of Yokohama 8.25 radials, but I don't think they make them any more. These guys have 20" tube required in Bias. Samson is one of the better Chinese brands. I use them on my forklifts. http://www.nebraskatire.com/truck/carTheir top of the line is Yokohama. They could tell you whats available. They might still have some NOS | | | | Joined: Mar 2011 Posts: 11 New Guy | New Guy Joined: Mar 2011 Posts: 11 | Hello and Welcome
I also have a 54 6500, Can you post pics of your wheels and truck
IDAHO
| | | | Joined: May 2021 Posts: 4 Moderated | Moderated Joined: May 2021 Posts: 4 | I too am new to the forum. I’ve always wanted an old truck to fix up. So now I have a 49’ 6400. For me it will be a lot of work. I’m a newbie. I think the split rims are ok in Florida? Anyone know for sure? I just always thought you get replacement conversions. I’d like to just put tube tires back on. The ones on it need to be replaced. They hold air and I can drive it up I’m kinda afraid to go more than just around then square.
I don’t even know where to start. Seems like everything in life. You wade in. The truck was still worked 8 years ago. Grain truck from Nebraska.
Jay She may be ugly! But she’s paid for!
| | | | Joined: Mar 2004 Posts: 6,189 'Bolter | 'Bolter Joined: Mar 2004 Posts: 6,189 | Jay, Welcome  You've posted to a thread that was started in 2006 and was last posted by my50chevy in 2017 and he hasn't been here since December. You should stop into the "Welcome Center" and introduce yourself and then start a new post in "Big Bolts". To answer your question, if you have solid ring two piece rims, they are still serviceable as long as they aren't rusted to bad. Any Big Truck or Ag Tire shop will work on them for you...car tire shops will not. Mike B  | | | | Joined: Nov 1995 Posts: 5,470 Bond Villain | Bond Villain Joined: Nov 1995 Posts: 5,470 | You also might find Tech Tip informative
~ John "We are not now that strength which in old days Moved earth and heaven; that which we are, we are" 1948 International Farmall Super A1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump2001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | Joined: May 2021 Posts: 4 Moderated | Moderated Joined: May 2021 Posts: 4 | Thanks... will do. I’m new to all this I will figure out the forum eventually as well.
