Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (3B, Ridgeback, baldeagle, JW51, TexasA&M48Truck), 37 guests, and 0 robots.
Topics128,005
Posts1,055,253
Members48,418
#1492043 03/14/2023 5:16 AM
Custom Title
Custom Title
I just got my girlfriend a '65 K10 for her birthday. I'm 99.9% sure the engine has been swapped and I'm trying to figure out what it originally came out of, just out of sheer curiosity. Block casting is 3850817, 1962-1978 230/250. Stamped code by the distributor is F0624LK. I stuck my borescope in a spark plug hole and it has dished pistons so that says it's a 250. I've been digging and can't find the LK suffix code. The only one I found came up as a 427 and that's clearly not right. Any help is appreciated!
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
Can't help with the suffix code, but the dished pistons definitely make it a 250. Both engines have the same bore- - - -3 7/8", but the 250 uses the dished piston to keep the compression ratio the same as the shorter stroke 230 engine. Flat top pistons for a 307 V8 are a drop-in fit for a 250, BTW, and they give a pretty good compression boost.
