6 members (Eileen, klhansen, Uncles51, DBJ71SuperCustom, dt235sd, fonz8261), 99 guests, and 3 robots.
Topics128,079
Posts1,056,295
Members48,441
Junior Member
Junior Member
Hello All. Instead of rebuilding the one barrel on my '48 6400, I'm considering just buying a new one. Which carb would be the best application right out of the box? ie: Holly? Rochester?
Rezman
Snapoff brand tools
1948 Chevy 6400
1949 Chevy 4400 (parts truck)
I would rebuild the one you have.They are easy to do.Hey Carbking,what do you think.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Junior Member
Junior Member
It's kind of rough, I know it could be probably be rebuilt. But I'm wondering what would be a suitable current replacement.
Rezman
Snapoff brand tools
1948 Chevy 6400
you can get carbs that are professionally rebuilt from oldparts vendors. I got one from American classiics after I screwed up one NOS I got local
I'm always leery about rebuilt carbs from big parts venders.(parts stores)I've seen enough of them to turn me off.Seems they have them done by children, as cheap as they can so you get em cheap also.I redo them myself,as then you know when putting them on where the problem is as I know the carb is right.With a parts store rbuild you havent seen inside it so you could have dirt, jammed screws,wrong floathights just to name a few.Tom
Riding in the Passing Lane
I agree on rebuilding the one you have unless you are good at fabricating. When changing carbs you run into problems with linkage, fuel lines, & air cleaner mounting. Like Grub says about half of the rebuilt over the counter are not any good. The closest thing to matching are the Carter carbs from the same era. Maybe Carbking will come in & help out or you can E-mail him.
1972 Chevy c10 Cheyenne Super
V
V Offline
I rebuilt the Rochester on our 6400 and it was easy. If I can do it, you might give it a shot.
