6 members (TUTS 59, HandyAndy, dt235sd, Bill Hanlon, 2-Ton, Brian Moore), 109 guests, and 2 robots.
Topics128,060
Posts1,055,836
Members48,427
My ‘49 Chevy pickup was missing the hood latch spring. I’ve got a new one but have nothing to go by to install it correctly. Would very much appreciate any advice, video or diagram of one . Looks plenty simple but just can’t seem to get it right. Thanks!
1949 Chev 3800
Rubidu8,
Gonna move this question over to the "Paint and Body Shop" as that is the best place to get help on your topic.
AM sure a fellow 'Bolter will be in shortly to try and help with your problem. thumbs_up
Dan wave
~ Dan
1951 Chevy 3 window 3100
Thanks!
1949 Chev 3800
Thank you!
1949 Chev 3800
Thanks to everyone who responded. A picture is worth 1000 words. Got it done! David
1949 Chev 3800
On the safety catch hook, the spring has to be installed so that the hook is pushed toward the back of the hood. Originally the pin holding the safety catch went thru two tabs bent downward on the hood latch panel, but the repop ones are bolt-on, complete with spring. You have to remove the bent tabs to install them. Sample repop hood safety catch
[on edit] I see I'm literally minutes too late. blush Glad you got it fixed up. thumbs_up
Rubidu8 My new spring came with a rivet that was too small for the 51,so the pin was 1/4 inch when I drilled it's riveted end off (to get it apart) was too short. I got a 1/4 inch rivet drilled for acotter pin and washer now works fine,good fit can still get it apart. The 2 spring tails go toward the radiator.
