| | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 95 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 95 | My ‘49 Chevy pickup was missing the hood latch spring. I’ve got a new one but have nothing to go by to install it correctly. Would very much appreciate any advice, video or diagram of one . Looks plenty simple but just can’t seem to get it right. Thanks!
1949 Chev 3800
| | | | | Joined: Sep 2009 Posts: 5,830 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,830 | Rubidu8, Gonna move this question over to the "Paint and Body Shop" as that is the best place to get help on your topic. AM sure a fellow 'Bolter will be in shortly to try and help with your problem.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
1949 Chev 3800
1949 Chev 3800
| | | | | Joined: Jul 2019 Posts: 95 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 95 | Thanks to everyone who responded. A picture is worth 1000 words. Got it done! David
1949 Chev 3800
| | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | On the safety catch hook, the spring has to be installed so that the hook is pushed toward the back of the hood. Originally the pin holding the safety catch went thru two tabs bent downward on the hood latch panel, but the repop ones are bolt-on, complete with spring. You have to remove the bent tabs to install them. Sample repop hood safety catch[on edit] I see I'm literally minutes too late.  Glad you got it fixed up.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Rubidu8 My new spring came with a rivet that was too small for the 51,so the pin was 1/4 inch when I drilled it's riveted end off (to get it apart) was too short. I got a 1/4 inch rivet drilled for acotter pin and washer now works fine,good fit can still get it apart. The 2 spring tails go toward the radiator. | | |
