8 members (Gdads51, Otto Skorzeny, warlock, RoadsScholar, Ponchogl, 55shaker, k2handyman, 5 Window 9434), 104 guests, and 2 robots.
Topics128,048
Posts1,055,626
#1490520 03/04/2023 2:34 AM
Here’s hoping this won’t be as contentious of a topic as motor oil!!
What is your preferred assembly lube? and any reasons why?
LubriPlate?
Amsoil?
Permatex?
Melling?
Etc?
TIA
Paul
NAPA, Perfect Circle, Melling, Sealed Power, and several others sell about the same stuff- - - -looks like red-colored thick motor oil with some sort of sticky additive. I used to use STP as assembly lube, but every engine I built with the stuff seemed to have oil-related problems. I even built one more engine just convince myself it was a fluke- - - -and that one spun a rod bearing!
Usually use Permatex Ultraslick with no issues.
Redline assembly lube, because it stays where I put it. Camshafts get black sticky break-in grease. I built lots of engines with white lithium grease with no issues, switched over to Redline because it's thicker.
Fill the pump cavity with Vaseline
I like either
Lubriplate
https://www.lubriplate.com/Products/Grease/Multi-Purpose-Greases/100-Series/NO-105/C-105-AUTO-MA,-10-OZ-TUBE
Or permatex
https://www.permatex.com/products/l...x-ultra-slick-engine-assembly-lube-4-oz/
I have had very good luck with both.
Mike
53farmtruck #1490605 03/04/2023 10:20 PM
53 farmtruck I like to use something that wont leak out,so I can still air hose in there a little. Once the lubed cam is in place then work to get it closed up. Early on used GM EOS (cam lube) kinda messy. Probably lubriplate,gonna prime it anyway, never did pack any oil pump of any brand. Lately with all this cam/lifter trouble not sure what is best for our low spring pressure cams. Some use outboard motor gear lube,some gun grease,so ??? Like Hotrod said try to do just right...spin a bearing.
There are several brands of this, https://www.summitracing.com/parts/sum-camlube625 , its a black sticky grease that won't just wipe off, use it on camshaft and lifters. Don't use a liquid type on a cam, 90% percent of will be in the pan before you get it fired up. As for grease in the oil pumps, it shouldn't be needed, I usually pull new pumps apart to clean them, then add some assembly lube. If it's a used pump, I dump oil in it and go. My engines get primed and run on a test stand, never had one yet that would build oil pressure right away.
Joe H #1490807 03/06/2023 10:49 AM
Joe H Before battery drills I'd just use a speed handle,till the rockers got oil. Someplace I saw a guy pack a mopar pump seemed like a lot of grease to me !!
I build Pontiac engines, the oil pump sets below the oil level so they prime with no issues. I've seem them packed clear full for some reason also.
