1 members (klhansen), 65 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
#14905 06/18/2003 7:07 PM
I
Junior Member
Junior Member
I Offline
Which carb is better the Carter W-1 or the YF?
#14906 06/19/2003 3:04 AM
Carburetion specialist
For a daily driver, the YF is better. Much better metering circuits in the YF. The only real problem with the YF can be the diaphragm type accelerator pump. If driven only occasionally, the gasoline in the bowl can evaporate, leaving the inside of the carburetor dry. Diaphragms don't like to be dry once they have been in gasoline. They show their displeasure by becoming brittle and cracking, rendering them useless.
The W-1 is a much older design (1932 vs 1950). Accelerator pump is the much preferable leather. After the leather dries out, simply refilling the carburetor with gasoline will soak up the leather, and the accelerator pump will perform.
Personal opinion - on a scale of one (awful) to ten (wonderful), I would rate these as follows:
1932 - 1933 W-1 (5)
1934 - 1936 W-1 (5.5)
1937 - 1948 W-1 (7)
1949 W-1 (7.5)
1950 up YF (9.5 if used as a daily driver, otherwise 6)
1950 up Rochester B (5)
Jon.
The Carburetor Shop
#14907 06/19/2003 5:27 PM
Thanks for the ratings, Carbking! I had a YF carb on my '75 AMC Hornet that I sent to the knackers. If I can find one of those, would it be a simple switch for my W-1? What about the YF's heat tube that went from the bottom of the exhaust manifold to the carb?
(I wish I knew I was going to get my truck before I got rid of the Hornet's carb.)
