0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | i have a 61 apache was 6 with 3 on tree. im putting a chevy 302. im using a 61 front engine mount, it looks like a big u. my qustion is its goin behind a saganw 4 speed . what tranny mounts work. can i use the stock mounts ?
1961 apache
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Suspending the engine/trans assembly without some support at the bell housing will break the bell housing. You'll need a 1961 V8 bell housing with the hydraulic clutch setup, with the throwout fork and slave cylinder on the passenger's side. Then it will be a bolt-in swap. Saginaw 4 speeds have a cast iron case- - - -no rear mount should be needed, but a universal tubular mount the hotrod shops sell would be an option. DO NOT do the front/rear mount setup without supporting the bell housing. Jerry
| | | | | Joined: Feb 2023 Posts: 374 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 374 | I just installed a Gen V 454 in a 66 c10 with manual clutch I used the original 66 bellhousing & new stock rear motor mounts. Worked very well I’m using a m20 4 spd with a 66 11 inch clutch. It all fits like it came from the factory that way. FYI, if your 61 came with a 235 6 cyl, you’ll need to get a v8 bell housing. If you’ve got a later 230 or 250 6, then tha by will fit your 302 | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Assume we are talking about 302 small block V8 and not 302 in-line GMC 6.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | thank you guys, i did forget to say i have a v8 bell housing behind the 302 v8. and im using the slave from the 6 banger. this is wunderfull news
1961 apache
