7 members (kades51, Forty9, Peggy M, greenie-reddy, ShopRag, Bill Hanlon, 1 invisible),
88
Mod | | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2022 Posts: 7 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 7 | I have a small seating gas leak from bottom of my gas tank. Looks like there are 3 plgs in bottom of gas tank with someking of sealant over them. Is this a repaired tank or did they gave Thea plug things
Andys
| | | | | Joined: Sep 2009 Posts: 6,034 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,034 | Bird man, Any way you can post some pictures of the problem you are describing???  A standard in-cab gas tank for your '52 should not have 3 "plugs" in the bottom of the tank. There should be only one threaded port that your fuel line shut-off valve is threaded into near the passenger end of the tank that protrudes out of the cab floor. Post some pictures and we can try and better answer your question.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Oct 2021 Posts: 6,962 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,962 | Yes. Pics will help but someone's been monkeying with it. I assume they also drilled holes in the floor board for the two extra fittings?
You can get a brand new Canadian made tank for under $200 and the proper drain cock fitting for it for a few dollars more.
1950 Chevrolet 3100 (Ol' Roy)
