1 members (JW51), 115 guests, and 0 robots.
Topics128,081
Posts1,056,078
Members48,434
#14889 05/23/2004 4:11 AM
What seals the wheel cylender from leaking.The metal puck or the ruber one?Ron
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#14890 05/23/2004 4:46 AM
Y
Junior Member
Junior Member
Y Offline
I would say the metal puck centers the rubbercup in the bore to seal. My opinion is good luck
Chuck
#14891 05/23/2004 5:56 AM
the metal is the piston, the rubber is the seal - the outer rubber boot is the 'safety' - if there's any wetness outside it, you need new inner rubber cup, or new cylinders - the rubber can't seal a rough/scored surface
