| | | Forums66 Topics128,077 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14889 05/23/2004 4:11 AM | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | What seals the wheel cylender from leaking.The metal puck or the ruber one?Ron
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | |
#14890 05/23/2004 4:46 AM | Joined: May 2004 Posts: 4 Junior Member | | Junior Member Joined: May 2004 Posts: 4 | I would say the metal puck centers the rubbercup in the bore to seal. My opinion is good luck
Chuck
#14891 05/23/2004 5:56 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the metal is the piston, the rubber is the seal - the outer rubber boot is the 'safety' - if there's any wetness outside it, you need new inner rubber cup, or new cylinders - the rubber can't seal a rough/scored surface
Bill | | |
