3 members (Peggy M, Pre '68 Dave, 1 invisible), 101 guests, and 2 robots.
Topics128,031
Posts1,055,434
Members48,422
#148869 10/18/2006 1:26 AM
Apprentice
Apprentice
I am working on a 52 Chevrolet 2 ton, and we need new tie-rods/tie-rod ends. Can anyone tell me what the front axel weight for a 2 ton might be? Or even better, what the part #(s) might have been. This is the last thing I need before going "mobile" and I'm itchin...
Sam
52 chev 2 ton
sam
#148870 10/18/2006 2:36 AM
Try your local NAPA Store. You might just be surprised!
#148871 10/18/2006 7:48 PM
Sam you might try Mid-Canada suspension thats where i got the suspension parts for my 53 2 ton
Area code PH: 204-475-3399 Fax 204-257-8466
Good luck
#148872 10/18/2006 8:31 PM
Sam the Meat Man,
Boy, what a handle!! I did some investigating, and found a few things. If nothing else, I will get a 'A' for effort.
I think your truck has a (capacity) 4500# front axle. The tie rod ends for this rig appear to resemble the more modern style with a 1X16 TPI thread configuration..RH and LH.
I have enclosed a link to some dope! Hope some of this helps.
http://www.partsamerica.com/ProductList.aspx?parttype=80&ptset=A&searchfor=Tie+Rod+End+-+Driver%2c+Outer
Stuart
#148873 10/19/2006 12:45 AM
Sam the man,
The original part numbers are 609747+48, I probably have them NOS. E-mail me if interested [email protected]
#148874 10/19/2006 2:54 PM
#148875 10/20/2006 1:00 AM
Apprentice
Apprentice
Thanks to all for your invaluable help. We are in the process of locating them locally, but I may be back to some of you Bolters who have in stock.
Sam
52 Chevrolet 2 ton
sam
#148876 10/24/2006 8:34 PM
Apprentice
Apprentice
Chevyb, I just emailed you.
Sam
52 Chevrolet 2 ton
sam
