1 members (baldeagle),
118
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | I am working on a 52 Chevrolet 2 ton, and we need new tie-rods/tie-rod ends. Can anyone tell me what the front axel weight for a 2 ton might be? Or even better, what the part #(s) might have been. This is the last thing I need before going "mobile" and I'm itchin... Thanks, Sam 52 chev 2 ton
sam
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Try your local NAPA Store. You might just be surprised!
| | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | Sam you might try Mid-Canada suspension thats where i got the suspension parts for my 53 2 ton Area code PH: 204-475-3399 Fax 204-257-8466 Good luck | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Sam the Meat Man,
Boy, what a handle!! I did some investigating, and found a few things. If nothing else, I will get a 'A' for effort.
I think your truck has a (capacity) 4500# front axle. The tie rod ends for this rig appear to resemble the more modern style with a 1X16 TPI thread configuration..RH and LH.
I have enclosed a link to some dope! Hope some of this helps.
http://www.partsamerica.com/ProductList.aspx?parttype=80&ptset=A&searchfor=Tie+Rod+End+-+Driver%2c+Outer
Stuart | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | Sam the man, The original part numbers are 609747+48, I probably have them NOS. E-mail me if interested [email protected] | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | | | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | Thanks to all for your invaluable help. We are in the process of locating them locally, but I may be back to some of you Bolters who have in stock. Sam
52 Chevrolet 2 ton
sam
| | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | Chevyb, I just emailed you. Sam
52 Chevrolet 2 ton
sam
