4 members (KEVINSKI, DadsFirstPickup, Hanks custodian, Ponchogl), 198 guests, and 1 robot.
Topics128,108
Posts1,056,230
Members48,436
i'm in the process of gathering parts to change my boys 52 GMC 1500 transmission from the old 3 speed to a Saginaw all synchro 3 speed with OD. we have just about everything but the shift linkage, we want to stay on the column. are there better linkages then the 52 oem? are later model like 60s that are different and might work better ( a 60's pickup with this trans in it) will the shift linkage work?
thanks Jay D.
The side cover is completely different on the Saginaw transmission. The spacing of the shift levers is wider than the original so
fabrication and bending of the shift rods will be necessary. 60's columns were different also. Good luck even finding those components.
Fred
I switched my 54 to a T5 5-speed. Just drove it a little while ago and will more in about 2 hrs. Of course, it will need a floor shifter.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
