5 members (Ponchogl, Otto Skorzeny, Materman, dt235sd, walter74), 104 guests, and 1 robot.
Topics128,049
Posts1,055,634
#1488365 02/18/2023 2:51 PM
The casting number has been ground off this 261 head. Has anyone ever seen this and know why. The date code on it says it is a 55 261 head. I have no history on the engine other than it was painted a light metallic blue when I got it and had a rebuilt by (the only thing I could read ) sticker on the block. Just something that I seen when I overhauled the engine and wondered why someone would do that.
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
Never seen that before. big_eek
Not a clue why??? headscratch
Maybe another member has a thought.
~ Dan
1951 Chevy 3 window 3100
I'm confused, if the casting number is missing, how do you know it's a 261 head?
The casting number in your pictures are numbers/letters used by the foundry and are of no value to us now. Post pictures of any other numbers you have on your head and we'll try help figure out what you have.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Has exhaust valve rotators which 261 does, casting number should end in 850.
BC
1960 C60 pasture art
All 261 heads will have steam holes on bottom between cylinders, if no holes it's a 235.
1946 1/2-Ton Chevy
It has steam holes and the other side of the head has the 848 and 850 numbers. It's a 261 head. I'm just wondering if anyone would know why someone would grind off the casting number. It's not a special head or anything so why do it it, why hide what it is. It just pushed my curious button.
Jammer I don't see any grinder tracks .Sorry , I see what you mean now, but wouldn't the number be on a flat place ??
Maybe it's a 848 head off of a 235 and when they modified it by drilling the steam holes they didn't want to mix it up with non-modified heads in the shop.
The side of the head with the 848 and 850 numbers are there so the foundry knows which sand cast mold to use when casting either of those two different heads which share that same part of the mold.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
