6 members (Bill Hanlon, Donf, MickeyP, Hotrod Lincoln, mick53, FAST55), 109 guests, and 1 robot.
Topics128,049
Posts1,055,701
#1488279 02/17/2023 11:41 PM
W Online: Content
In looking up some info on old Chevy dipsticks, I came across this:
55-57 ALL (6 cyl) (2nd Ser) ( exc. D-D)
There's another reference to: (exc. D-D, COE)
What does the D-D stand for?
Detroit Diesel
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
A 57 Cadillac grill?
2 Offline
Double duty
Aka: step van
Usually a 1 ton chassis but doesn’t share much at all with the pickup
Good for:
Bread delivery, dry cleaning, mail carrier, packages etc
D-D is not a coe but just as ugly
"56, actually
We called 'em Bumper Bullets.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Originally Posted by 2ManyTrucks
Double duty
Aka: step van
Good for:
Really? I always thought it was Detroit Diesel. I think even on this site I saw that but learn something new every day.
2 Offline
The definitions of all the letter codes and acronyms are in the beginning of all the parts manuals
D-D as the post asked above is definitely double-duty in this case.
It’s important to decipher all the codes when you are planning your part hunt trip to the junk yard
Some parts are shared across a vast majority of vehicles so you can pick up a much less worn out part sometimes by looking places no one else does
Like at a D-D truck for instance smile
-s
62401
Indeed -- Context is everything.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Crusing in the Passing Lane
While D-D stands foe Detroit Diesel in another context, Double Duty applies here.
Ed
H Online: Content
Those Caddy front ends were also known as "Marilyn Monroe" grills!
Bumper adornments also called "Dagmars" after a famous beauty of the day.
2 many trucks I have been watching for the wheels on your final bread truck picture since 1982. My 51 3600 has that dual wheel differential and added leaf springs to haul canned milk in the 50's because single wheels couldn't take the load. I knew the guy who fixed that up but never got the axle he used. Iv'e always thought the axle was GM. Have hauled 25 years worth of firewood with it plus winch truck duty,still alive and well !!
2 Offline
The d-d trucks had the same 18 inch split rims as the 1 ton dualies?
Photo attached of one of my dual 1 ton 53s
That rear rim configuration is very common and cheap and easy to get up in Saskatchewan, those rims go for like $50 each up there.
-s
2 Many Trucks Just saw your ton ,my rear axle has a stubby hub just like that. Had a ton one oh ten years ago but never made the hookup between the two. Was afraid it might be out of a binder or worse. S o is Chevy ,think I put a pinion seal in it just used the numbers. Had to make a driveshaft and done a little cheating on the carrier bearing to get straight but is fine,and had some big loads and steep hills worked good !! thanks for the picture.
1940 Dubl-Duti
Model KP
3102 CCH chassis
The first generation of General Motors multi-stop delivery van was called the Dubl-Duti , introduced in 1940. The van was built on the ½ ton, 113½’’ truck chassis, with a body built by Divco Twin. They produces 16658 for 1940.
Was that truck built on the same frame as the Suburban/pickup?
