0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
I’m new to this, but pretty sure this is suppose to have a cover. Please check out the photos! Best I can tell, it’s the shift control shaft on the steering rod/column. It goes on a ‘49 Chevy PU. I don’t see it listed in the parts of some of the catalogs I’ve got, unless of course I’m looking for the wrong thing since I’m not sure the name of it! Any idea where I can get one??
Cover missing
Cover missing!
Cover missing!
That is your shift lever/linkage. Remind us what year your truck is?
You might consider putting that info in your signature.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Thank you. I added it. It is a ‘49 Chevy AD 1/2 to. PU
Yes, that definitely should have a cover on it. Without it, the shifter shaft is unsupported (bearings at top and bottom) and shifting may not even work correctly. You may have trouble finding just the cover, but might be able to come up with a complete shift box.
Try the swap meet here, or maybe try Jim Carter. I believe they offer rebuilding service for the shifters and may have a cover available or a complete used one.
Any idea where I can get one, short of a junk yard? Thanks.
Great! Thank you so much! Checking on that now.
Dang! Out Of stock!!
Bummer
Give Jim Carter a call. They may still be able to help you out if they have a cover laying around. They'll probably want you to ship them your incomplete box to them first if they do.
Also post an ad in the Swap Meet. Another Bolter may have a spare.
Crusty Old Sarge
Crusty Old Sarge
I second posting an add in the Swap Meet Parts Wanted forum. There are plenty of parts to be had if you just ask.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Where are these being sold?
Here's one on ebay
Link
SuziQ,
Check your ad in "Truck Parts Wanted" for a reply with a possible source.
Dan wave
~ Dan
1951 Chevy 3 window 3100
What is the big hole in the center for?
A snap in sheet metal plug goes there as a fill port cover.
