| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Can the door hinge on 1946 Chevy pickup be tightened with bronze bushing, and the hinge? I found the 1947 bronze bushing. Are the 1946 and 1947 bronze bushings the same?
Harold Is a restoration ever finished? | | | | | Joined: Jul 2006 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 36 | depending on your skill level the best way that i found to repair the 39-46 door hinge is to drill the hinge and put in a bigger pin. The problem is that you will have to make the new pin. i used a piece of 5/16 stainless rod turned down to fit the hole and i heated up the end and hammered out a new head. i do not remember what size bit i used and it really doesnt matter because it depends on how worn your hinge is. drill first and make pin second. i do think that there are new hinges available but i am not to sure on how accurate they are in appearance and fit. i hope this helps. | | | | | Joined: Jul 2006 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 36 | i looked at my notes on my 39 and the drill bit i used on the hinge was a 19/64. i dont have a lathe at home so i chucked the pin in my drill and turned it against my belt sander until i got it to correct size.
