5 members (Steelonsteel, Tyler Watts, RaNfLaS, rfs56trk, DadsFirstPickup), 101 guests, and 2 robots.
Topics128,048
Posts1,055,663
#1486652 02/05/2023 10:35 PM
Looking for input from anybody that has converted a 60 - 62 pick up with this set up?
Manual transmission (T5), hyd. clutch, drum /drum, inline 6.
BC
1960 C60 pasture art
BC59 #1486752 02/06/2023 5:36 PM
I put something similar in a 67 C-10 with a stick shift. Worked out great.
1936 GMC T-14 restro-mod
BC59 #1486941 02/07/2023 8:52 PM
I have recently purchased this for my 66. Have yet to install.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
BC59 #1486978 02/08/2023 12:11 AM
The hydraulic clutch makes the 60 - 62 a bit more involved, thus more $$$.
Clearance between brake booster & intake manifold one question I've got.
BC
BC59 #1487005 02/08/2023 2:24 AM
Since the 60-62 uses a 2-chambered MC, one side for the brakes and the other for the clutch, it might be necessary to use a separate unit for the clutch. With a little tinkering, a clutch MC for a mid-1960's Dodge pickup might be able to be adapted for operating the clutch slave cylinder. My 65 D100 with a 318 V8 was set up that way.
BC59 #1487053 02/08/2023 5:40 PM
R Online: Content
It appears that the clutch MC is included in the photo shown. It also has a separate shaft for the clutch pedal.
So it may have everything needed for the conversion. It also appears to be a CPP set up. As far as I know the components are OK
but they are notorious for providing poor installation instructions.
Several other aftermarket sources provide these same conversions.
Fred
BC59 #1487065 02/08/2023 7:32 PM
Ok- - - -it seems that they did a good job of hiding the second MC in their photo. Given the tiny diameter of the booster chamber, have you considered just investing in a gym membership? A few reps on a squat machine would male your leg stronger, which is all the booster does!
lLOL!
rfs56trk #1487100 02/08/2023 11:46 PM
Fred
Thanks for the input Fred.
If I get one it will be from The Filling Station, I make it over to the wet side of the state every now & then.
I highly recommend stopping in & checking them out if you are traveling I 5 in Oregon.
BC
