4 members (frogfarmer, BillCollins, VicZ, oldsteve), 111 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
I'm putting new parking brake cables on a '53 3800, but i assume they are the same as 3100 or3600 other than length. There is small plate that goes on either side of the backing plate that positions the cable. Both of the plates are on the cable, with the ends crimped on so they can't be removed. Will the inner plate fit through the hole in the backing plate? I looked at it a minute or two and it seemed close, but didn't fit in my minute or so of trying. If i get it positioned right will it fit through? I don't see how else to get it together since the ends are crimped on. Thanks,
Josh
Josh,
A picture of what you have is worth a 1000 words. Can't tell what "plates" you are trying to describe or their placement, so difficult to offer help. ohwell
Can you post some pictures of what you have and where you are trying to install it???
Show us what you have and we can try and help from there. thumbs_up
Dan
~ Dan
1951 Chevy 3 window 3100
Just guessing, but probably both plates install on the outside. The one closest to the backing plate is probably just there to seal the back side, assuming it fits flat against the backing plate. The cables for 3100's are similar, and both plates go on the outside of the backing plate with a thick felt gasket to seal them.
Like Dan said, a picture is worth 1000 words.
2 Offline
They both go on the outside
I have a photo but it’s too big to post via iOS
I can shrink it later on laptop and post it if no one else has by then
-s
I’m not sure how to post pictures, but it makes sense that they would both go on the outside. Where does the felt go? Between them? Between the inner one and the backing plate?
AD Addict & Tinkerer
The felt as, Klhansen pointed out, goes between the plates and the backing plate.
Phil
Project Journals
Stovebolt Gallery Forum
