7 members (greenie-reddy, klhansen, carbking, Mike B, Hotrod Lincoln, cmayna, Woodcmiami), 60 guests, and 2 robots.
Topics128,030
Posts1,055,421
Members48,422
#1486398 02/04/2023 3:24 PM
When I redid the brakes on my 52 half ton I found the backer plate adjustment hole plug was missing on two of the wheels. The remaining two plugs were metal that clipped into the holes. Am I correct to assume these are the original style? Are they available today? I replaced all with rubber.
1952 Chevy Pickup Truck
papas52 #1486404 02/04/2023 3:41 PM
Pretty neat. I've never seen metal plugs on any old car and that's all I've ever owned.
I wonder if they originally had a thin rubber seal bonded to them?
1950 Chevrolet 3100 (Ol' Roy)
papas52 #1486406 02/04/2023 3:55 PM
papas52,
From what I could gather here Group 5.188 - Cover is the Master parts Catalog listing for these. See snapshots below for more details. Your metal ones were definitely original equipment.
A web search for GM# 475516 provided links for sales listings (none mine) in eBay for NOS or OER items and reproductions available from Chevs of the 40's (https://www.chevsofthe40s.com/detail/6298/Chevrolet_Brake_Adjuster_Hole_Plugs_Original_Metal.html)
Your call if you want to use the rubber ones you already have or if you want something period correct???
Hope this answers your questions.
Dan
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1486412 02/04/2023 4:26 PM
Wow, Tks Dan.
Cheap enough, will order some.
Again, THANKS.
papas52 #1486424 02/04/2023 5:56 PM
7
7 Offline
My 70's and 80's GM trucks had the steel plugs. When I was in my local chain parts store and asked for rubber brake adjustment plugs they didn't have a clue, didn't even have any hanging on the Dorman peg display.
papas52 #1486452 02/04/2023 9:17 PM
papas52,
Your most welcome! Glad it was helpful. thumbs_up
I find that using the first "FREE" source link Old Online Chevy Manuals is often my first stop when trying to search for part identification, pictures, part numbers and so on for most trucks in our community.
Once you have an original part number, it is usually (not always) easy to do further web searchs to help you find sources both old and new.
Is saved as one of my "favorites" and get used frequently. grin
~ Dan
Otto they used to all be just metal,I remember when they showed up on the dorman rack.
papas52 #1487091 02/08/2023 9:22 PM
Rustbucket Ranch
Rustbucket Ranch
Surprisingly, my '58 1 ton had those as well. Popped them off and stashed them somewhere headscratch
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
Possum #1487479 02/12/2023 1:14 PM
Possum Keep em atashed in your backing plates, a friend always called those vacuum plates.
