| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 16 'Bolter | | 'Bolter Joined: Feb 2017 Posts: 16 | I've seen a lot of 47-54 trucks where interior is painted same color as the exterior and many where interior is a basic gray paint or something else different from exterior. Curious if original trucks had similar paint schemes and, if so, was it considered a delux model if interior painted same as exterior? | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | Original paint scheme was that gray/brown that you see allot. Interiors that were painted the color of the truck are not how they came from the factory.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Early AD pickups thru '52 used a color called Medium Tan Metallichrome, a semi gloss, slightly metallic color. In 53, GM went to a color called Sheen Gray Poly, and in 54-55 a color called Pearl Gray Here are a couple of photos of repainted doors that are real close to the original color for 47-52. I bought from Jim Carter and needed to lighten it a bit to match the original parts on my truck that still had paint on them. The two pics had a bit different lighting so look different. Like Phil said, any truck interior painted exterior color wasn't factory.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | Here is a link for the paint colors on 50-53 AD’S. 50-53 Interior Paint Colors
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Here Is the info from the tech tips, which is where I got my info from. That link of Phil's is limited in year range. But still good info.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | The interesting thing about the original interior paint is that it changes color like a chameleon depending on the angle which it is viewed and the light source.
