4 members (farmallb, Gib70, Gdads51, Nick in Manitou), 132 guests, and 3 robots.
Topics128,088
Posts1,055,998
Members48,430
#1486353 02/04/2023 1:49 AM
I've seen a lot of 47-54 trucks where interior is painted same color as the exterior and many where interior is a basic gray paint or something else different from exterior. Curious if original trucks had similar paint schemes and, if so, was it considered a delux model if interior painted same as exterior?
AD Addict & Tinkerer
Original paint scheme was that gray/brown that you see allot. Interiors that were painted the color of the truck are not how they came from the factory.
Phil
Project Journals
Stovebolt Gallery Forum
Early AD pickups thru '52 used a color called Medium Tan Metallichrome, a semi gloss, slightly metallic color. In 53, GM went to a color called Sheen Gray Poly, and in 54-55 a color called Pearl Gray
Here are a couple of photos of repainted doors that are real close to the original color for 47-52. I bought from Jim Carter and needed to lighten it a bit to match the original parts on my truck that still had paint on them. The two pics had a bit different lighting so look different.
Like Phil said, any truck interior painted exterior color wasn't factory.
Here is a link for the paint colors on 50-53 AD’S. 50-53 Interior Paint Colors
Phil
Project Journals
Here Is the info from the tech tips, which is where I got my info from. That link of Phil's is limited in year range. But still good info.
Clark6400 #1486493 02/05/2023 12:51 AM
The interesting thing about the original interior paint is that it changes color like a chameleon depending on the angle which it is viewed and the light source.
