0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#1485936 02/01/2023 2:01 AM
I’m planning to replace my original 1946 Chevrolet AK 4spd non-synchro “crash box” transmission, with an original 1946 3spd transmission. If I’ve researched correctly, this is a direct fit R&R. Is that correct? Any changes needed or are they an exact swap?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
Is the 3-speed trans a truck floor shift trans? If so it should bolt up to your bell housing.
I don't know if the floor hole is in the same location, but that would be an easy fix...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
Yes, all the 41-46 AK trucks were floor shifts. Base was the std 3sd with synchronized 2nd and 3rd gear. The optional transmission was the heavy duty 4spd with non-synchro on any gear. Straight cut gears with no synchros, not even on 4th gear.
The only thing you will need to address is the master cylinder mount.
The four speed is wider than the three speed, so the mount wont quite reach the new transmission.
You can simply put shim washers between the mount and the transmission, or find a three speed mount.
My Blog
Thanks Pre ‘68 Dave. No difference in Torque tubes are there?
The front yoke that bolts on the transmission is different between three and four speed, but the rear yoke and torque tube are the same, for 1/2 tons anyway.
My Blog
Thanks again, Pre ‘68 Dave. So, I assume the front yokes will interchange, is that correct?
Are you talking about the yoke that attaches to the universal joint?
Quote
I assume the front tiles will interchange, is that correct?
Not sure what you mean by tiles?
And yes, the universal joint yokes.
My Blog
Sorry about that. Fat fingers + autocorrect!
I didn’t mean to type “tiles”. It was supposed to be “yokes”. Sorry about that.
The front yoke does not interchange. The rear shaft of the two transmissions are different.
My Blog
One last question…..is the “bell” that seals the torque tube to the transmission the same for both 3spd and 4spd…..or will I need to replace it too?
Same.
My Blog
