4 members (Bigsts, klhansen, UtahYork, 78buckshot), 61 guests, and 3 robots.
Topics128,185
Posts1,057,286
Members48,467
Yeah went to the yard and the guy had some bud style wheels and a 2 speed axle on a bus that would bolt right up but he wants me to buy the whole bus for like 850 bucks and I still have to get it out. The guy tried saying he would give me a deal with the 850 because scrap is lower than it was in the summer. And I just told him I would think on it because the bus has no motor or grill and only weighs like 7k max so like 400 bucks max the way scrap is going. But I went to another yard I found and the guy has a bunch of old stuff although mainly Dayton's.
At the yard I did find a 2 speed axle with Dayton's and hydraulic brakes(2 speed and hydraulic brakes are my requirements for this) and the whole yard was under water at some point but they guy is nice and said I can take it apart before buying it and come out during the day to look through the rest of his stuff because I only went through like maybe 4 acres out of 60 and he has a bunch of old stuff in there. One thing I have a question about though is if I bought the axle and I am going to look for a part number as well to do some research, how hard are Dayton's to deal with and would someone like me be able to work with Dayton's on something like this and is there anything I should know about Dayton's. I do know that when you take them off you need to loosen the nuts and then jack the wheel up and break it loose to avoid sending the pucks flying but I have read stuff about them wobbling when installed wrong. What would be the best way to stop that. If I need to make a separate post I will.
1967 Chevy c50 327 w/ sm465 5000Ib front 15k 2 speed rear w/ 22k springs, single axle, hydraulic brakes
Crusing in the Passing Lane
Make sure to check the diff ratio first to make sure it fits your needs, many older ones are low and lower which would not be useful!
Ed
Last edited by Peggy M; 01/13/2023 2:17 PM. Reason: fix title - thread was moved from BB
That's why I want the numbers I also want to be able to maybe get parts for it
Last edited by Peggy M; 01/13/2023 2:18 PM. Reason: fixed title as thread was moved from BB
I just junked a 2-speed Eaton (electric shift) 6-lug Budd rear that was on a low mileage fire truck chassis three weeks ago (think it was rated at 18K)...shipping from Maryland would be a killer.
There are millions of trucks out there running Dayton's, so there can't be that many issues...go talk to your local big truck tire shop for tip on mounting/installing them.
Mike B
Last edited by Mike B; 01/14/2023 1:21 AM. Reason: deleted line about moving thread since it got moved.
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Authorized Pest
Authorized Pest
As suggested, moved this part of a discussion from Big Bolts ( about patching ) to here (Driveline).
Have at it boys. grin
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Might have to see how much it would cost to do that mike haha I think I am getting desperate
I found the numbers on those rears the guy had 2 of the same ones and one isn't seized but had some water the other one didn't have the axle shafts and was in a position where there wouldn't be water and I was wondering if anyone could identify these
https://imgur.com/a/bTEcJPw
I also found a front end here are the numbers 10-18-57
The bottom numbers are hard to read, could you wire brush and rub with talc, etc to help out? Usually the high number is stamped. Can always turn by hand and count!
Ed
I think that bottom number is the ratio it has a 6 then a small circle and 2 3s
I also found another guy with axles that I know would be good but the problem is the front axle springs are 1 in off of mine how hard would it be to move mine to match up with his
Thick and Ed,
Here is a blown-up/rotated crop shot of the stamped numbers that may help decide what this unit is.
2 speed axle stamped code
~ Dan
1951 Chevy 3 window 3100
So, perhaps high is 6.33, not very useful.
Ed
I believe this rear is a Eaton Series 13, rated at 15,000 pounds.
82956 is the production assembly code.
H2205 is the plant and date code.
6.33 is the gear ratio with 8.81 being low gear.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Ok so that would be a usable axle for my truck then but I think I may go with something else. I found a guy with a 82 c70 that he is parting out and is selling axles for way less than what the guy at the junkyard is asking for and it would mean I get newer brakes axles and also I would be getting a full set that the suspension matches up better and only requires some welding on the front hangers and I am not throwing some random front end I found at a junkyard under there that doesn't line up on a lot of it.
Thoughts? I know it's kind of a lot but this is just a big step in this project
Thick Chevy,
If you fill out your profile, we will know what truck you are working on.
Ed
Ok
Well, if those axles bolt up, sounds like a good idea. Might want to see if the brake drums have any ‘meat’ left if possible. What is the wheel bolt pattern of the axles?
Ed
If I went and got the axles from that c70 they are 22.5 Daytons(I think 6 spoke) and disk brakes and I can actually get everything for the brakes too.
I am really leaning towards this solution even though I would be a little wider on the front axle but I will still be inside the fender and I would probably have to weld in new hangers up front because my leafs are 2.5in and his are 3in wide.
And I should be able to hook up the steering pretty easily too I would hope Chevy kept them fairly standard?
22.5 wheels are a bonus, easy to change, anywhere.
Ed
Yeah that's what I am thinking because I would like to get some slightly more aggressive tires and 22.5 I can get about whatever I want in recaps
Well I got the axles from the guy I wasn't able to get the front springs because we were under a bit of a time crunch and couldn't get to where we could cut them out so just cut the u-bolts and now I need to figure out brakes on this but I think we were definitely pushing the limits of my van with 4 people and a bunch of tools and equipment and probably not gonna do that again before I get bags
Was the fire part of the plan?
1950 Chevrolet 3100 (Ol' Roy)
Sure let's go with that lol
