1 members (KEVINSKI), 160 guests, and 2 robots.
Topics128,108
Posts1,056,228
Members48,436
I am putting a 292 six back together, and am doing the connecting rods right now. I have a '71 factory overhaul manual, but there is no listing in the torque specs for the 292, only the 250. For the 250, it says 11/32-24 bolts and 35 ft/lbs. This 292 has 3/8-24 bolts, like a small block, and the small block are torqued to 45 ft/lbs.
Con rod bolts are kind of critical, would hate to use the wrong torque on them. Anyone know for certain what the correct torque value is?
thanks,
JW
Motor Magazine Truck & Diesel Manual, 36th. Edition:
292 connecting rod torque: 40 ft./lbs. A 292 runs the same part number connecting rod bearing as a small block V8- - - -2.100" standard size.
Thanks Jerry!
And yes, I figured that about the bearings. Explains why the rod bearings were like $1 each, while the mains were $10 each!
cheers,
I use a slightly modified 292 connecting rod when I'm putting a 235 crankshaft and pistons into a 216 engine block and eliminating the Babbit bearing rods and the spray-oiler lubricating system. It turns a 216 into a 235 and still looks like an original 216.
