6 members (Donf, Shade Baby, Jon G, Bill Hanlon, rfs56trk, Hotrod Lincoln), 154 guests, and 0 robots.
Topics128,105
Posts1,056,208
Members48,436
Does anyone have a recommendation for changing from the 6v gen system? A 6v alt would be simple but is there also a 6v high voltage coil/distributor option or do you need to go 12v to make that happen?
Authorized Pest
Authorized Pest
Been suggested to move this to the Electrical Bay. You'll get good coverage there here. thumbs_up
~ Peggy M
1949 Chevrolet 3804
H Online: Content
There is a 6V conversion of a GM 10-SI alternator that's virtually a bolt-in swap. Just fabricate a bracket that aligns the belt pulleys properly and bypass the charging system wiring at the voltage regulator. That "high voltage" ignition system modification is a solution in search of a problem, as long as you're willing to do a little regular preventive maintenance on the original ignition system.
Thanks Peggy, will do.
Hot Rod Lincoln: that sounds like good advice. A little maintenance is fine with me and the 6v alt sounds simple. Thanks
H Online: Content
For instance:
www.ebay.com/itm/334103047439?
If your generator runs the wide belt, order it with the 5/8" pulley.
B Online: Content
... but Jerry's "For instance" is a negative ground alternator while Greasy Knuckles' "53 GM COE" (if GMC) left the factory with a positive ground electrical system.
6v positive ground alternators in a 10SI case do exist.
Authorized Pest
Authorized Pest
Greasy,
Did move it for you. Seems to be a good move. smile
~ Peggy M
1949 Chevrolet 3804
Yes it is a positive ground system. Thanks for the 10Si info. And thanks Peggy for moving it to the electrical forum.
H Online: Content
OK- - - - -try this one! The manufacturer can probably supply whatever width pulley you need.
www.ebay.com/itm/114816167511?
LOL!
Thanks for the link, I’d order it except they won’t ship to canada. Will look around for other suppliers.
Sir Searchalot
Sir Searchalot
Can't imagine not going to 12V neg ground with alternator. Amazon 10si 12V alternator $55 and free ship. By the time you pay shipping of the ebay style alternator to Canada, you will be over $300. You can do that whole 12V conversion for that.
Insomniac
Insomniac
Maybe you could build your own as shown in this video. www.youtube.com/watch?v=euUFrwWh_0M
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Sir Searchalot
Sir Searchalot
Very neat video Gord. Looks very easy. good job finding that.
Greasy Knuckles: Seems to me the Delco DIY is WAY better.... and WAY cheaper.
You say "A 6v alt would be simple but is there also a 6v high voltage coil/distributor option or do you need to go 12v to make that happen?"
Make what happen? Put on the 6V Alt and go down the road. It has nothing to do with coil or Dizzy.
Gord&Fran Good job on landing that video for 6 v alternator neg ground. It's also just as easy to make 1-wire delcotrons .
