11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2021 Posts: 27 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 27 | Does anyone have a recommendation for changing from the 6v gen system? A 6v alt would be simple but is there also a 6v high voltage coil/distributor option or do you need to go 12v to make that happen? | | | | | Joined: Apr 2004 Posts: 5,078 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,078 | Been suggested to move this to the Electrical Bay. You'll get good coverage there here.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | There is a 6V conversion of a GM 10-SI alternator that's virtually a bolt-in swap. Just fabricate a bracket that aligns the belt pulleys properly and bypass the charging system wiring at the voltage regulator. That "high voltage" ignition system modification is a solution in search of a problem, as long as you're willing to do a little regular preventive maintenance on the original ignition system. Jerry
| | | | | Joined: Sep 2021 Posts: 27 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 27 | Thanks Peggy, will do. Hot Rod Lincoln: that sounds like good advice. A little maintenance is fine with me and the 6v alt sounds simple. Thanks | | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | For instance: www.ebay.com/itm/334103047439?If your generator runs the wide belt, order it with the 5/8" pulley. Jerry
| | | | | Joined: Jan 2022 Posts: 2,466 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,466 | ... but Jerry's "For instance" is a negative ground alternator while Greasy Knuckles' "53 GM COE" (if GMC) left the factory with a positive ground electrical system.
6v positive ground alternators in a 10SI case do exist.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Apr 2004 Posts: 5,078 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,078 | Greasy, Did move it for you. Seems to be a good move.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Sep 2021 Posts: 27 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 27 | Yes it is a positive ground system. Thanks for the 10Si info. And thanks Peggy for moving it to the electrical forum. | | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | OK- - - - -try this one! The manufacturer can probably supply whatever width pulley you need. www.ebay.com/itm/114816167511?LOL! Jerry
| | | | | Joined: Sep 2021 Posts: 27 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 27 | Thanks for the link, I’d order it except they won’t ship to canada. Will look around for other suppliers. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Can't imagine not going to 12V neg ground with alternator. Amazon 10si 12V alternator $55 and free ship. By the time you pay shipping of the ebay style alternator to Canada, you will be over $300. You can do that whole 12V conversion for that.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2000 Posts: 2,195 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,195 | Maybe you could build your own as shown in this video. www.youtube.com/watch?v=euUFrwWh_0M
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Very neat video Gord. Looks very easy. good job finding that.
Greasy Knuckles: Seems to me the Delco DIY is WAY better.... and WAY cheaper.
You say "A 6v alt would be simple but is there also a 6v high voltage coil/distributor option or do you need to go 12v to make that happen?" Make what happen? Put on the 6V Alt and go down the road. It has nothing to do with coil or Dizzy.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Gord&Fran Good job on landing that video for 6 v alternator neg ground. It's also just as easy to make 1-wire delcotrons . | | |
