1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1480086 12/22/2022 11:57 PM
H Online: Content
What's the proper color to paint a 1951 big truck 235 engine? I'll be building a period-correct looking engine soon, an original engine with a serial number matching the vehicle title, and I'd like to be able to paint it and decal it correctly. I believe the 235 spray oiler in the big bolts was known as a "Jobmaster", right? Does anyone have a source for the right valve cover decals?
Jerry, All Chevrolet engines from 1929 thru 1953 were the same 'Blue-Gray' color.
Can't help with the decal...someone with an original valve cover needs to post a picture of the cover so it can be reproduced!
Merry Christmas!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
H Online: Content
Thanks, Mike
Jerry,
I pulled out my 48 page original brochure for 1951 Chevrolet Trucks. The 235 splash oiler was called "Loadmaster 105" and, you guessed it, the engine had 105 horsepower. There is only one picture of the chassis where you can sort of see the valve cover decal... see attached picture. It would actually be 4 decals separated by the 3 sets of vertical bars on the splash oiler valve cover.
1. Load-
2. Master
3. 105
4. Engine
The font looks to be the same as the more common "Thriftmaster" decal.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
H Online: Content
Thanks, Kent! The one I'm building will have a few internal improvements that will make that "105" less than accurate, but I'm trying to make it look as close to original from the outside as possible.
Good thing they included the word "engine" on the decal.
1950 Chevrolet 3100 (Ol' Roy)
Hirsch has an Chevy engine grey that is pretty much spot on.
https://www.hirschauto.com/ENGINE-ENAMEL/productinfo/EE-QUART/CHV%20GREY/
As far as I know, the "Loadmaster 105 Engine" it was not a decal, but stenciled.
Frank
Rustbucket Ranch
Rustbucket Ranch
The Jobmaster was the 261 smile
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
When I painted my original 1940 1/2 ton engine, I bought paint from Jim Carter that claimed to be the correct color. When I painted the engine for my 53 half ton, I bought PPG paint using the number code that I got somewhere on this site. Both paints are gray, but the PPG paint is darker gray than the paint from Carter. I don't particularly care, I just thought I'd share that in case it could help anyone.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
H Online: Content
42 bucks a quart- - - - -that Hirsch paint looks like a bargain. That's enough to paint a bunch of engines, and I've got a trim spray gun and enamel reducer to make it easier to apply and more economical than anybody's overpriced rattle can paint. Thanks!
If you end up using the Hirsch paint you can brush it on directly out of the can, it will lay down like glass even on the sheet metal parts...the brush strokes just melt together. Less clean up that way!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I think Jim Carter had the correct blue-gray color engine paint as well. I got my 261 valve cover decal from him too.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Meanwhile in Germany...
...a Friend of mine just had some stencils cut for his engine.
If you still need them, I can ask him if he sends me the vector file, so you can have it cut locally.
Frank
I've made decals using laser printer decal paper that's available from most office supply stores (i.e. Staples) or online.
If you take it to a place that has a color laser printer, they can do it in color for about a buck a page. The ones I made were for oil filter tops (there weren't S-2 filter canister decals available from the usual vendors.)
Wouldn't be hard to make a valve cover decal. You could make it say whatever you wanted. wink
Example of a custom decal for S-2 filter lids.
Load Master 428 Cobra Jet
keep 'em guessing.
@Stovebold6: Can I get those files? I have a cutter for them and wouod be willing to make stencils available for the community.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Moderator, Electrical Bay
You can also get waterslide decal paper made for inkjet printers. You just have to remember to coat them with clear (enamel, urethane, etc...rattle can is fine). If anyone has the vector files (or better yet JPG files) I probably have some decal paper left over from the speedometer work.
And...some folks may not know it, but you can use a rather new type of transfer paper called SunnyScopa film-free. What you do here is have the decal professionally laser printed in whatever color you want (image quality---high definition)...with the image reversed (meaning flipped on the page). Then you transfer it to the subject just like a waterslide, put that in the oven for a few minutes and the laser toner is bonded to the subject. Advantage is there is no decal "edge". It looks like it was silk screened on once the film is removed. The maker says time makes it tougher.
~ Jon
Jon G: How well do the waterslide decals hold up to the heat in an application like this? Have you tried it?
A valve cover should stay pretty cool compared to the rest of the engine, but I don't know what the upper temp limit is for the decals.
They do very well...I suspect better than the cricut vinyl stuff over time. In fact I applied one to my valve cover, decided I didn't like the look of it and had to work to get it off. Strong vinegar will do it, but usually you have to repaint after that.
~ Jon
Oracal makes some high temp vinyls, but they really don't like the chemicals you find under the hood. The removable stiff makes a good stencil but I would not prpbably not use any of them as a permanent sticker there
Originally Posted by buoymaker
Here is what "Brush Script Std" looks like from "Font Zone". Be careful not to download from an unsafe site. The file name is BrushScriptStd.otf. It is an Open Type Font. Copy to your Windows/Font folder (if using Windows). Anything that uses the files in the Windows/Font folder will be able to access the added font. I typed in the text in Windows Wordpad. Selected yellow characters with gray background. I resized and cut-n-paste into Windows Paint (old version). What I did is very basic stuff. A business that makes signs, decals and stencils will have the capability to make a more accurate job.
I am looking at the zero of the "105" on the valve cover in your pic, and it looks like that script on the actual valve cover was applied by spraying yellow paint through a stencil. I am basing this on the breaks in the yellow paint of the zero. The rest of the script on the valve cover is pretty blurry and faded to see other breaks which would indicate that it was applied through a stencil.
Not that it matters to sane people, but some of the rest of "us" are curious about how the script was applied. smile
I saw that , too. I'm sure the factory used stencils just like the army used to mark equipment and crates.
I doubt you'll ever find a "restored" AD with crooked looking stencils and a pine bed painted black. If Chevy built the trucks to the standards that restorers apply to them, they'd have had to charge as much as new Cadillac
Every post i have seen and any other research I have done says there is no known paint code. The various factories mixed their own paint and it was a blue gray but slight variations from one plant to the other. the closest I found was a F**d engine gray. there use to be a Chevrolet engine gray but it was discontinued several years ago. I used Chevy orange and Chevy blue for the oil cannister. Classicparts.com has the Job Master valve cover decal except they show it for the 261. they don't have the big bolt 235 version. Valve cover decal
Dave from Northern Kentucky
My 54 3100
In 1954, over in GM's Corvette plant, they were applying decals to the "Blue Flame 150" (https://www.ebay.com/itm/275386899806).
Do you know for a fact the Corvette's used decals (not arguing, just trying to learn)? Nothing in the eBay listing confirm it's and actual GM issued decal set.
I got instructions like those back in the 70's for decals used on my 1935 Chevy Coupe. I always thought they used a silk screen method at the factory to apply the lettering which would keep the letter edges crisper looking...maybe the low production Corvette's did it differently?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Interesting that the Corvette's used decals (maybe due low production and them being installed on the radius of the cover ohwell ) and the trucks seemed to use silk screen or stencils.
Always something to learn here.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
The Dave Graham Thriftmaster engine decal sold by RockAuto (and others) is broken up as if it were a stencil. Why make a decal look as if it were a stencil unless the original actually was a stencil?
https://www.rockauto.com/en/catalog/chevrolet,1950,truck,3.5l+217cid+l6,1487136,accessories,decal,12471
Probably because the original was actually a stencil.
Yes, that was my point.
There has to be plenty of small town fire departments who still have an AD firetruck for nostalgic purposes that still have legible script on the valve covers. I thought I found one in Wachapreague, VA, but to no avail. It is a GMC. It is a sight to behold nonetheless.
The search continues...
