3 members (Lostbuthaulinass, Ponchogl, RLB), 71 guests, and 3 robots.
Topics128,049
Posts1,055,743
#1484254 01/19/2023 10:45 PM
Can anyone tell me if a Delco heater motor 47536 is 6v or 12v? My 47 3600 had everything 12 volts when I bought it, but I'm not sure about the heater motor. I'm restoring it back to what it was before, with the 59 235 and 4 speed trany. So far, I rebuilt the Engine, Trany, Brakes, Gauges, all Glass, Body work, Seat, all in the last year. I would be farther along but I'm waiting for painting to be done. As I'm reassembling, I want to know if my heater motor is 6 or 12v. It does run on 12v, I jumped it to a battery.
1947 3600 Chevy
lumbersawyer #1484262 01/19/2023 11:34 PM
Insomniac
Insomniac
Partial part number? 5047536? GM parts wiki shows this:
http://www.gmpartswiki.com/getpage?pageid=68358
1950 would be 6 volts. My 6 volt heater motor ran like a banshee on 12 volts, so I installed a 12 to 6 volt reducer to slow it down to an acceptable noise level.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
lumbersawyer #1484264 01/19/2023 11:46 PM
Moderator, Electrical Bay
Sorry but I don't have any information about that particular part number. I can tell you 475351 was a 6v. But that number doesn't come up in anything I have. 475351 was used from the late 30s to late 40s I believe. Please take a look and see if there are any other numbers...maybe a longer string that begins with a 504.....
~ Jon
lumbersawyer #1484266 01/20/2023 12:02 AM
Looking at the wire going into the motor it is cloth type I would think it is 6 volt
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
lumbersawyer #1484271 01/20/2023 12:22 AM
That is the only numbers on it what you see in the picture.
Delco Appliance 47536
Some town in NY. USA
1947 3600 Chevy
lumbersawyer #1484273 01/20/2023 12:23 AM
I should just not trust it and get a new 12v motor
1947 3600 Chevy
lumbersawyer #1484276 01/20/2023 12:50 AM
There are some 12v motors on the big internet auction place. The only 12v replacement fan motor made in the USA that I know of is sold by Old Air Products in Fort Worth: https://www.oldairproducts.com/product/blower-motor-12-volt-20-3615
~ Jon
Sir Searchalot
Sir Searchalot
I agree a little with Kevin but they could have replaced it and used the 6V wiring. If that cloth wire is integral to the motor, it's 6V.
I would think a 6V run on 12V would almost be a hovercraft.
You can test it for 20 minutes using a 7A-10A fuse. Probably should have the squirrel cage on it to create a little load. The speed and the amp draw may give a clue. None of the above is totally definitive. Otherwise, as you said, get a 12V motor.. Which of course, is not all that easy sometimes. Hard to search internet "replacement 12V fan motor for a 47 Chevy truck." Except possibly in Stovebolt Search smile
You CAN find one by diameter and length of housing....... diameter, length and shape of shaft...... Give us that info and a couple good pics of the motor if you want, and we will find. You probably should replace it during a refurbish anyway. PITA to get to again.
There are methods to electrically and physically determine, but beyond most folks capability and not 100%.
lumbersawyer #1484306 01/20/2023 12:54 PM
Thanks, I ordered a new 12v motor. I don't want to do it again.
1947 3600 Chevy
I am not sure what your 12v motor cost. I did a lot of research when I rebuilt my heater and converted to 12v. I found a replacement at AutoZone. Part #35512. Everco. Heater blower motor. Current $38. It is variable speed. bolted right in, and is reversible. The only modification was I shortened the shaft (cut it off). I re-used the existing blower fan.
Everco blower motor
Dave from Northern Kentucky
My 54 3100
dgrinnan #1484326 01/20/2023 3:10 PM
Everco blower motor
What switch did you use for this motor. Standard for your '54, or something else???
~ Dan
1951 Chevy 3 window 3100
lumbersawyer #1484856 01/24/2023 12:21 PM
lumbersawyer If your heater motor is 6 v and it looks like it is,it will scream on 12 volt. You can use NAPA voltage reducers to tame it,mine has run a long time that way. Just follow their directions. Using the original 2- speed swich always run it on hi speed.
lumbersawyer #1484860 01/24/2023 12:59 PM
I used the original 2 speed switch. It doesn't care 6v or 12v.
My 54 3100
Thanks Dave! thumbs_up
~ Dan
dgrinnan #1484988 01/25/2023 3:28 AM
dgrinnin That's it works good,fired up and sat out in the sun today,big snow tonight so will stay in might go pack the snow on my road,no salt there.
