0 members (), 132 guests, and 1 robot.
Topics128,285
Posts1,058,276
Members48,483
#1483733 01/16/2023 1:43 PM
Hi all, I got a question on removing the door lock on my 1950.I see it has a clip that hold the lock in place. I have tried to slide it over
but won't move. I am hoping somebody will chime in on this. thank you
I use lineman's pliers on those. The jaws width is about perfect for a secure grip. A lot of wiggling and pulling is required to work a rusty one loose.
Thank you sir,
I had a lot of trouble removing mine in part because the clip was hitting on the inside of the opening in the door edge that it slides through. Not sure if it suppose to get inside the door but mine was making removal that much more challenging.
1949/50 3600 Project
Follow in Project Journals
I believe there are a couple of pointy things on it that help hold it in place and make it more difficult to pull out. I recall using a putty knife, an possibly a screwdriver behind that to get mine out. The weatherstrip is in the way also.
