0 members (),
132
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,276 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2022 Posts: 24 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 24 | Hi all, I got a question on removing the door lock on my 1950.I see it has a clip that hold the lock in place. I have tried to slide it over but won't move. I am hoping somebody will chime in on this. thank you | | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | I use lineman's pliers on those. The jaws width is about perfect for a secure grip. A lot of wiggling and pulling is required to work a rusty one loose.
| | | | | Joined: Sep 2022 Posts: 24 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 24 | | | | | | Joined: Nov 2021 Posts: 1,439 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,439 | I had a lot of trouble removing mine in part because the clip was hitting on the inside of the opening in the door edge that it slides through. Not sure if it suppose to get inside the door but mine was making removal that much more challenging. | | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | I believe there are a couple of pointy things on it that help hold it in place and make it more difficult to pull out. I recall using a putty knife, an possibly a screwdriver behind that to get mine out. The weatherstrip is in the way also.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
