1 members (delky),
258
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2023 Posts: 1 Moderated | | Moderated Joined: Jan 2023 Posts: 1 | Help - Trying to ID year on my 235 thanks. Behind starter is (1238) and stamped below distributor is (FI2238), on the head carb side on top of head is (3836848). Thank you for your help. I’m new to this forum.
jack
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | This should help you figure it out. What you need to look for is the number cast into the block above the right side oil pan flange toward the front of the engine. Just to the rear of the distributor is the engine serial number. Since this is your first post, Welcome to the site. Suggest that you head over to the Welcome Centre and post an introduction there about your truck and yourself.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2020 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 69 | For the 1957 model year, Chevy ditched the long serial code. So, looks like you have an engine manufactured at Flint MI on 12/23/56 (for the '57 model year). The '8' you specified on the end of the serial number is likely a 'B'? If it's a 'B' it would have been originally equipped with a Powerglide and should have hydraulic lifters. For confirmation on the year, check the conveyor number above the starter. Yours should be CON# L##6. The 6 at the end the conveyor number means it was made in 1956 (for 1957 model year).
I think this is correct, it's early and I haven't had my coffee yet...others will chime in if I'm off the mark!
Welcome to the forum!!!
Mason
1947 Chevy 3100 -57 Chevy 235 -95 S10 T5 Transmission -97 Blazer 3.42 Rear End
| | | | | Joined: Feb 2020 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 69 | Sorry, I just noticed you mentioned 1238 behind the starter...could that be L238? If so, it was made Dec 23 1958 which would be for the 1959 model year
Mason
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Sorry, I just noticed you mentioned 1238 behind the starter...could that be L238? If so, it was made Dec 23 1958 which would be for the 1959 model year With a build date of Dec 23rd (F1223B), it's unlikely it was machined and assembled on the same day you're saying it was cast. Could the cast date be Dec 3, 1958 (1238)? Pictures would help...  Welcome to Stovebolt  Mike B  | | |
