0 members (),
129
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | What model trans came stock in a 1941 COE? Is it the same as a conventional truck? What years would it fit? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Same as conventional, just different shifter!
Ed
| | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | what model what make? what years would it fit?
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | what model what make? what years would it fit? Chevrolet 4-speed (nick named the "crash box"). This is a non-synchronized trans used from 1941 to 1947. Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | This trans does not have the bottom right mounting bolt offset like ‘47 to present GM trans.’
Ed
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I believe the transmission is made by GM and is called GKT-134. Regarding fitment it spans at least 1937-1947; I am not sure when it started production. Kent | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Chevrolet 4-speed (nick named the "crash box"). This is a non-synchronized trans used from 1941 to 1947. Mike B  Typo on my part...this trans was used from 1931 to 1947. 1931 was the first year for a 4-speed in a Chevrolet truck... Mike B  | | |
