4 members (Peggy M, Shade Baby, Gray_Ghost, NorthCoast3800), 130 guests, and 5 robots.
Topics128,120
Posts1,056,321
Members48,439
The distribution brake line block on the rear of an AD master cylinder is not available new (that I can find) so going to machine some. It is the fitting that is held to the m-c with a hollow banjo bolt. Although I use a lathe and mill on a daily basis I am NOT a trained machinist and have run into a problem. The OD of the flare seat is larger than the ID of the fitting threads so a tool to cut the seat cannot pass through the threads without cutting them away. Any suggestions ???
Evan
Do you have a picture or a diagram? I am having a hard time envisioning the piece.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Undercutting behind a thread is going to require interpolation so a CNC mill will be necessary. As for the cutting tool these guys are my go to for such applications:
https://www.harveytool.com/
You Tube
Evan
The MC on my '51 just has a single line attached to it and uses two division blocks over on the right side of the frame, one splitting front to back and another splitting to RF and LF. The one you're referring to is used on only some AD's (52 and later?) I think I may have seen them somewhere, which would be easier that machining your own. Have you looked HERE?
I think you could cut the seat with a tool ground small enough to cut the seat and the undercut on a lathe, feeding it in parallel to the seat angle, either before or after the threads are cut.
AD Addict & Tinkerer
This I believe this is the fitting Evan is talking about.
Phil
Project Journals
Stovebolt Gallery Forum
You don't have to have a CNC for that. On a lathe it is relatively simple to use a trapezoidal cutter on a boring bar to do it. Set the angle of the blade for the angle of the seat, move it down the axis of the hole inside the threads, then bring it (radially) out at the bottom of the hole and finish the cut. Then reverse to get the cutter back out.
It takes some planning and attention to the geometry for your depth, but can be done manually by someone with moderate skills.
It would take some thought on how to do it with a mill unless you had a few extra axes to play with.
That looks very similar to the banjo bolt fittings on the rear wheel cylinders on my '51 with Bendix brakes. There should be lots of those around.
[on edit] Here's one (might be different threads) Link
Looks like there are plunge cutters available for this. The undercut at the back is probably a thread relief groove rather than a taper that is larger than the minor thread diameter.
https://www.tristareng.com/j512-tooling/
You Tube
With the exception the banjo bolt is bored and and machined for a 1/4 inverted flare fitting.
Phil
Project Journals
H Online: Content
Evan, there is a much simpler solution that requires NO special machining. The part can be made on a drill press. Call me.
Phil (phak 1) posted a picture of exactly what I need a supply of. Will call Jerry.
Evan
H Online: Content
If you have one to use as a pattern send it to me. I'll make you about a dozen of them.
Yes, but Evan said he was looking for the distribution block, not the bolt. The line coming off the master going to the LF brake is 3/16 as are the lines to the rear wheel cylinders.
H Online: Content
Make a square brass block to go under the banjo bolt with a 1/8" NPT threaded hole in it. Then screw one of these fittings into it:
www.ebay.com/itm/134273637068?
www.ebay.com/itm/115502079034?
The line coming from the back of the fitting in question, is 1/4” on a ‘52, and goes over to the passenger side to a distribution block. Front side on that distribution block. (now 3/16”) goes to the front passenger brake and the rear (also 3/16”) goes to both rear brakes.
I suspect the part Evan is talking about, the difficulty in machining, would be the the hollow bolt with the inverted flare machined inside. The block would be easy to make. The bolt not so much!
Phil
Project Journals
H Online: Content
The bolt can be made the same way. Use a 1/8" NPT thread in the bolt head and an adapter fitting. The tubing size becomes irrelevant, as there are thousands of factory made adapter fittings available in all sorts of tubing sizes. Why do people insist on making things difficult when there's a quick, inexpensive work-around available?
Moderated by  MNSmith
