7 members (Otto Skorzeny, UtahYork, arustycars639, Ponchogl, 5cameo8, Gray_Ghost, jmoore),
88
0
Mod | | | Forums66 Topics128,108 Posts1,056,562 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2022 Posts: 43 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 43 | First oil change, first canister change! ... Removed the bolt for the canister, but the top won't come off.
Is it just stuck or is there something else in need to do?
Also, it looks like there's a place on the bolt for an O-ring maybe? | | | | | Joined: Dec 2022 Posts: 43 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 43 | Top Off, filter out. The canister is full of oil. Should it be? I going to hand pump it out. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | The cannister drains through a small hole in the center tube, about 1/3 of the length from the top. In other words, the cannister should be about 2/3 full, not totally full. I use a turkey baster to remove the residual oil. Kent | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Be sure to wash the turkey baster before next Thanksgiving
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | Some filter housings have a drain plug in the bottom that makes the lob a little less messy. If a canister doesn't have a drain, it's an easy job to drill a hole, braze a pipe fitting in, and plug it. Jerry
| | | | | Joined: Dec 2022 Posts: 43 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 43 | Pumped it out, cleaned it out. The oil was pretty nasty looking.
All back together! | | |
