1 members (Hotrod Lincoln), 118 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
Big Bolt Forum Co-moderator
This post was originally posted by " Captain Hook" and I accidentally deleted it when I meant to move it to a new thread. My bad. It's a learning curve. dang
I like the brake issue update plans sounds great i am restoring my 52 coe with the orignal brake system so far i have all the new parts to make it work have problrm with the front wheel grease seals has anyone come up with a seal that replaces the old leather one with the metal washer that is supposed to keep the grease inside the hub ? thks retired tow truck guy
1948 Chevy 2-Ton
7
7 Offline
I am currently re-assembling the front end of my '57 2 ton. I also wanted to use a modern wheel bearing seal, with dimensions in hand I researched the various bearing and seal sites, I also used the original factory part number to cross reference. I came up with several cross-reference P/N's and I also was able to find seals by dimension. I ordered 2 from my local independent parts store, they showed only one available, so I tried it. The rubber lip is way too tight on the "shaft", the outer steel dimensions are close but I didn't try to install it 'cuz it seems too big. I ended up ordering 2 original P/N felt style seals from Old Car Parts North West, waiting for them to arrive.
Moderated
Moderated
hey thanks for the info i am in the swing of doing exactly what you did have not got to the parts store yet but if a guy can get replacements thats the way to go i will give those folks at old car a call thank you very much for the lead am new to the site you guys are sure a lot of help !!!!! by the way have you heard of anyone that has changed a coe updraft fuel carb to a fuel injection set up of any type just thinking thks capt.H
Captain Hook,
Just a suggestion, but maybe ask "anyone that has changed a coe updraft fuel carb to a fuel injection set up of any type just thinking thks capt.H" in the The HiPo Shop.
You will most likely get more answers there as it falls into that forum better than in "Big Bolts".
BTW - Glad you were able to pop back in. Looking forward to more questions and conversations!
While your posting, don't forget to introduce yourself and your truck in The Welcome Centre thumbs_up
~ Dan
1951 Chevy 3 window 3100
