6 members (Hotrod Lincoln, Peggy M, klhansen, IHPWR, DadsFirstPickup, 49choptop), 87 guests, and 1 robot.
Topics128,043
Posts1,055,605
When I disassembled my '51 3600 two years ago I didn't think to take note of how the front bumper brackets were oriented. Now that I'm fitting the front end sheet metal and grill I'm pretty sure I put the brackets on upside down. So the question is, are the brackets supposed to curve up or down? The drawing in the FAM appears to show them curving down. I've spent quite a bit of time looking through other folks' Project Journals for photos, watched YouTube vids, and various web sites. I can't find a image that confirms what I suspect. Many thanks in advance for your help!
Brian
'51 Chevy 3604 Project
'28 Chevy LO basket case
'83 GMC Sierra 4x4
I just looked at my truck.
The "belly" of the curve is on the bottom side.
1950 Chevrolet 3100 (Ol' Roy)
Curmudgeon
Curmudgeon
Sorry for the poor picture.
Fox Offline
Are 3/4 tons the same? I know the one tons are not and are mounted differently.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Here's some pictures that might help 1. Disassembled right after removing bolts - it's upside down to show what it would look like from under the truck looking up. 2 Then pre-assembly , and pic under the drivers side..... of my 1954 3604 . Hope this helps. If needed, PM me.
Ron - - Dusty53
1954 Chevy 3604
Fox , same as ? The 3100 ?
The 1947 - 1955 FAM indicates that the same part number brackets are used on Models 3100 , 3600, and 3800. Section 14 , sheet 1 .
Ron
Ron - - Dusty53
1954 Chevy 3604
Thank you all for the input and the photos. As I suspected, I have them on wrong. They are currently curving up so they are hard up against the pan under the grill. That just didn't seem right to me.
Brian
'83 GMC Sierra 4x4
Fox Offline
It looks like you boys got it figured out. Nice.
Yes, I was asking if the 3100 was the same as a 3600. They are based on the FAM. As for the 1 ton, mine has a different setup. My 1 ton doesn’t have those brackets at all. It has little stubby ones much closer to the frame horns. Granted, mine is a Canadian truck, but I couldn’t see that being much difference. Any other one tonners have similar mounts that are different compared to the 1/2 and 3/4 tons?
Here are my one ton mounts:
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
