9 members (carbking, Mike B, klhansen, Youngin' Tut 59, Pete1946, Gray_Ghost, BarryP, dt235sd, 1 invisible),
89
Mod | | | Forums66 Topics128,139 Posts1,056,758 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | I had my mechanic install an Okie bushing on my 1952 Chevy 3100 to stop the transmission oil from filling up my rear end. When that didn’t help they pulled the drive shaft and showed me where it was badly worn where the seal sits. They said I need to replace the drive shaft. Does anyone know where I can find one?
My dad always told me, "Don't force it, get a bigger hammer".
| | | | | Joined: May 2015 Posts: 11,122 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,122 | It would likely have to be a used one. Post an ad in the Swap Meet forums. There are likely a few complete rear axle assemblies laying around the Stovebolt collective.
The other option would be for a machine shop to build up and remachine the area that's worn. Or maybe a speedy sleeve could be installed.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,841 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,841 | A welding shop with some "hard-facing" rods can build up the worn area, and the repaired area can be brought back to original size on a lathe with carbide cutter bits and a tool post grinder. That might be simpler, and possibly less expensive than finding a serviceable replacement 60-somrthing years old. Jerry
Looks like Kevin and I had the same idea- - - -he's just quicker at the keyboard.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Just to be sure you know what the problem is…
An Okie bushing puts the seal on a new unused area on the driveshaft.
If your vehicle did not have an Okie bushing to start with then it is unlikely the shaft is at fault.
It is more likely that oil is leaking past the outside of your Okie bushing.
Torque tube ID varies greatly from year to year, and an Okie does not always fit the tube like you would like.
You may at least need to put some sealant on the outside of the Okie before installing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | They discovered my truck did already have an Okie bushing in it. The mechanic said he measured where the seal on the new bushing contacts the shaft and that is in the area where the shaft is worn. But I will pass along your suggestion to put some sealant on the outside of the Okie bushing when they install it. Tomorrow I am going on the hunt for a machine shop that can turn the shaft after I get a welder to build it up. Thanks everyone. Don
| | | | | Joined: Feb 2004 Posts: 29,841 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,841 | If you can find an automotive machine shop with a "submerged arc" welder, the kind that's used to build up crankshaft journals, it would create less distortion of the shaft than going after it with a stick or MIG welder. Jerry
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Tomorrow I am going on the hunt for a machine shop that can turn the shaft after I get a welder to build it up. Don Ask them if they can make you a custom Okie bushing to avoid wear/seal areas and leave the shaft as is.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2010 Posts: 2,329 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,329 | Maybe a few measurements and a shaft repair sleeve May be a option ,might be difficult or impossible to have it installed further down we’re the seal is. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | How is the shaft where the original seal ran? Might be easier to install a new seal in the stock position to catch what gets by the Okie.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | I have a question about my Okie bushing. Even though the shaft has been removed, since I already have an Okie bushing, I’m going to use it once the drive shaft has been repaired (I think I found a machine shop that can do the work). From what I’ve read when you install it the end with the seal goes on first. The two bushings in it are different sizes. The one next to the seal seems to fit the shaft while the one on the other end is bigger. What fits into it? Is there something that slides over those splines that fits into this bushing?
| | | | | Joined: May 2015 Posts: 11,122 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,122 | The rear half of the u-joint runs in that bushing in the front of the driveshaft tube.
