| | | Forums66 Topics128,049 Posts1,055,691 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | What do you guys think is the shelf life of a rebuilt fuel pump for a 1962 235. | | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | It would depend on the environmental conditions that the shelf experiences. Cool and dry - Good. Hot and moist - probably not so good. You'd probably have to pull the fuel pump apart and look at the condition of the diaphragm. If it's cracked, it would need to be replaced.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,748 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,748 | How long ago was it rebuilt? If more than 10 years or so, it probably doesn't have an ethanol resistant diaphragm even if the rubber isn't cracked or dried out.
I'd plan on rebuilding it if you're uncertain of the rebuild date.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2016 Posts: 1,984 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,984 | If it has been stored in a shop with chemical vapors such as carburetor cleaner, moth balls, muriatic acid, etc. it might be compromised.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Treat most any NOS or rebuilt item that has rubber, neoprene or leather parts as a core if it has been sitting on a shelf somewhere for an extended time.
