6 members (Otto Skorzeny, 1955 1 Series, GrandpasJimmy, Hotrod Lincoln, BarryP, 1 invisible), 99 guests, and 1 robot.
Topics128,162
Posts1,056,925
Members48,458
Page 16 of 20 1 2 … 14 15 16 17 18 19 20
Rustbucket Ranch
Rustbucket Ranch
A needle scaler from Harbor Freight, would have gotten the one Eastwood offers but those were backordered.
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
Former Workshop Owner
Finally bought a complete set of 3/8 and 1/2" drive impact sockets. Both standard and deep, Metric and Inches. After having good luck with the 3/4' ratchet I purchased a few months back, I once again went with the Masterforce (Menards) brand. I don't need Snap On quality or their prices. According to my online research, they are made by Apex Tool Group. They are not marked stating the country from where they were made but seem to be of high quality.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Bought a 4 piece set of 3/8 drive Clutch Head bits. My original 50 year old set has disappeared so a new set was in order.
Fox Offline
Didn’t buy, but assembled this little unit from freebies.
Trailer: was free from my brother’s company. It was a former light tower trailer. I had to install some angle iron bracing under the welder. We also bought the 2x6 boards.
Spools: free. Dad picked them up at the dump. They were for water lines and leaked, but might work for welding cable.
Field welder: my bro in law bought 3 of these for a few hundred dollars each ( I know, right?! He seems to have horseshoes in his ...) when he and I were building drilling rigs together. He kept one, gave one to his dad, and has been letting my dad use this one on the farm. He has said to keep it there. Ah yeah, we can do that.
I think it will be a pretty sweet little unit when it’s all done.
I just have to remove the pintle hitch and install a ball hitch.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
After 30+ years of abuse my heavy commercial battery charger finally crashed. The boost feature quit several years ago and now only the trickle charger works. So, I bought a new commercial grade fully automatic charger/booster and it arrived today. It is a DSR by Schumacher. Hope it lasts as long as it’s predecessor.
O Online: Content
Where is it made?
1950 Chevrolet 3100 (Ol' Roy)
Probably China.
Crusty Old Sarge
Crusty Old Sarge
That's a mighty pretty garage floor Martin. Nice charger, hopefully as you said it will last as long as the other one.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Ms Kathy’s living room floor. It had just been delivered by USPS, it’s now out in the barn with all the motorized equipment. grin
Does a pill cutter count? I really did not buy it the VA sent it to me today. I had looked at them on Amazon but was sure that I had not ordered them. I was getting along fine with a paring knife doing a few at a time. But in their wisdom, the VA sent me 2. ohwell
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Moderator
Moderator
2 Offline
Cutting back on your drug use Ron? That is at least a start!
Nice charger Martin!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Got a motorcycle tire balancer. Plan to try it out in the next week or so. Supposed to work on big cruiser rims but my use will be smaller dual sport bikes. Same principle as the most effective R/C aircraft prop balancer everyone uses, consisting of a shaft with centering cones set between low friction bearings. Just gotta make sure everything's nice and level. Will set the ends on a couple of chairs or jackstands, whatever works.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Picked up a neat little bead roller. Specifically for hose (radiator) beads.
Also got these neat little doohickies. They will make straight marks down the length of various size tubing.
I assume those are for use with the tubing benders in your pic. They'd be good for making multi-angle bends along the length of the tubing. thumbs_up
Bought a little contraption called a TIG feeder. I have yet to try it out.
They are for marking tubing, curved or otherwise. A sharpie fits in the top or side holes snugly. I haven't used them yet but really could have when I was making the second and third row seats for the Burb.
I have been using the bead roller lately as I've been making up custom cooling systems.
I was checking those out. Let me know how you like it please. Now if they could make one to keep me from dipping my tip.
Adjust the tip so you can rest the cup on the piece you are welding? Similar to all those guys doing the "walk the cup" welding videos.
I try and not buy things that I don't know how to use. ohwell
2017 Buick Encore
See more pix
24601
24601
I had to borrow one of these at an auction not too long ago to jump the Cornbolt dump truck. Totally dead battery. This thing jumped the 392 IH Big Block about 6 times without running down or having any issue. I was amazed at how compact it is -- fits under the seat in the van.
I asked Mrs. Santa and she gave it to me early. NOCO Boost HD. says it'll do 40 starts on a single charge. Has a light, and a couple of power ports (standard cig lighter and a usb.
Now that I have it, I'll probably never need to jump a 12-volt vehicle again.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Looks like it'll take up less space than a set of jumper cables, and probably safer than asking a stranger for a jump these days.
Matthew 6:33
24601
24601
Skooter -- That's exactly what I'm thinking. We bought one for our daughter, too.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Insomniac
Insomniac
I got one of those NOCO boost GB70's last Christmas. It's great. Ditched the battery for the generator - just use this now. When the battery on the lawn tractor dies, I will use this. Portable starting power when needed.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
AD Addict & Tinkerer
I just bought a Rivet Nut Insertion Tool from HF. I originally bought just the rivet nuts so I can install new (really old) Shell style horns on the firewall, intending to use just a bolt and nut to install the rivet nuts, but discovered the it was not that easy. Seemed I needed more hands than I have, marred the face of the rivet and it didn’t compress evenly, so I decided a new tool was in order. After all, men can’t have too many tools! The reviews on the Doyle HF tool were really good.
I didn’t want to fasten the horns to the firewall using a nut and bolt for two reasons. The first is I would need my wife to help, and she would be too keen on laying under the dashboard. Second, I just installed the firewall pad and cover, so I don’t want to remove it to get access to the nut. I figure I could remove a couple of the firewall clips to gently pull the pad away from the firewall to drill the holes.
I tested it out using one of the supplied 1/4”-20 rivet nuts and it was easy. Now on to install the horns!
Phil
Project Journals
Stovebolt Gallery Forum
That looks like a nice set.
That is a nice tool. But being a cheapskate, I've installed rivet nuts with a nut and bolt to expand them. So far it has gone OK. If I have the need to set more rivet nuts, I may have to get one of those. Not that expensive.
I’m a cheapskate too and tried that route. Didn’t fare out too well. The rivet nut was turning unless I made the hole really tight. Then the nut scored the top of the insert and to top it off, the rivet didn’t crush evenly. I always wanted a rivet nut tool so now I had a reason to buy one.
Phil
Project Journals
The trick is a tight hole, and a greased washer under the nut. Another trick is a piece of aluminum or steel directly on the rivet nut (under the washer)that you can hold stationary.
I tried a couple of washers but I didn’t grease them.
Phil
Project Journals
O Online: Content
So a rivet nut is a rivet with internal threads?
I have never heard of this tool until now. I need one.
Brian
'51 Chevy 3604 Project
'28 Chevy LO basket case
'83 GMC Sierra 4x4
Big Bolt Forum Co-moderator
I bought a 3/8" tubing straightener. I'm replacing the vacuum lines on my two speed rear end and decided to splurge.
https://www.eastwood.com/eastwood-h...1497297&wickedsource=google&wv=4
1948 Chevy 2-Ton
I picked up this version. Love it! https://www.summitracing.com/parts/rus-654440
I no longer buy straight sections of tubing from my FLAPS. I'll buy it in 20'-50' rolls and straighten what I need! Steel, stainless. Doesn't matter!
Crusty Old Sarge
Crusty Old Sarge
Well technically I didn't buy this, it was a Christmas gift from my BIL. With the addition of my lift I had wanted a tall stand. This will definitely come in handy.
Tall Stand
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Gotta get down to HF and get one. They're having 25% off through Monday (New Year sale). Thanks for the tip! thumbs_up
Matthew 6:33
24601
24601
Well, it may not (yet ...) be an old truck tool, it *is* the most recent tool I bought ... I finally treated myself to a cordless reciprocating tool for Christmas. Whoa -- is this thing handy for a number of tasks! Most recently, I have been using it on a carpentry project (drywall ... frown I am a lousy drywaller ... but I am improving ...)
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Here's something I built/bought.
Made up the base and upright from some tube steel I had laying around (I think it used to be table legs), bought a 10' stick of 1-1/2 x 1-1/2 x 1/8 angle, and some locking casters off Amazon. Got it mostly done today and stuck one of the fenders on. Way easier to work on all the little rock dents in them bolted to the stand. Once both are cleaned up, I'll bolt the other one on the opposite side and primer and block them both. Then when the weather allows, it'll be a paint stand.
FENDER STAND FOR BODY WORK AND PAINTING
Now, that's handy!
Crusty Old Sarge
Crusty Old Sarge
Getting ready to start on my cab patch panels. I purchased a 20lbs pot blaster form HF. I view the item on line and the store showed 3 in stock, when I got to the store there was only one and it was a return. As the blaster had been returned it was an opened box and marked "Parts Missing". The manager had it discounted to $59.00. I went through the box and could tell it had been used not just opened, there was media still in the tank and the nozzle was broken. Other than the nozzle and the cheap plastic funnel being broken the kit was all there. I told the manager I would give him $40.00 for it, he said that with opened items you only had 5 days to return it if it didn't work. He discounted it to $40.00 and I took it home.
I haven't used it as yet but did replace the nozzle and added the air line fitting.
https://www.harborfreight.com/20-lb-pressurized-abrasive-blaster-68994.html
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Craig,
Just a WAG, but think you will get your $40 worth in no time once you put it to work. wink
Nice find! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Moderated by  MNSmith
