10 members (dwreills, Gdads51, 32Fordpuchoptop, chevy51truck, Phak1, klhansen, 52Carl, KEVINSKI, Woodcmiami, 1 invisible), 111 guests, and 1 robot.
Topics128,036
Posts1,055,458
Members48,422
#1478804 12/13/2022 8:40 PM
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/50409/filename/image.jpg[/img]Is this repairable or do I start looking for new frame?
1949 3100 frame
Justice #1478810 12/13/2022 9:17 PM
While just about anything can be repaired with enough investment of time, money and effort, would you be comfortable betting your life on a repair of a stressed point that carries the weight of the vehicle and absorbs every bump the spring encounters? Even if I played high stakes poker, I don't think I'd be betting on an inside straight like that repair would resemble. Frames in much better condition aren't all that scarce or expensive.
Justice #1478818 12/13/2022 10:21 PM
X2 what Jerry said.
Search your local ads (Craigslist, FB Marketplace, etc.) for a replacement frame.
Since you haven’t indicated what your working on, you can update your post to give folks more details (make/model/year) so they can maybe help point you in a good direction.
Don’t forget you can also post an ad in the Swap Meet “Truck Parts Wanted” forum too! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Justice #1478821 12/13/2022 10:31 PM
Authorized Pest
Authorized Pest
P Online: Content
Suggested we move this to Paint & Body forum. They may be able to give some more ideas.
~ Peggy M
1949 Chevrolet 3804
Justice #1478836 12/14/2022 12:03 AM
I have to agree with Jerry. I had some rust in that spot as well, but nowhere near that bad. The blaster called it "structural rust" meaning it had weakened the structure. I did some repairs to mine, but wouldn't attempt it on that one.
It could be repaired, but it would be time consuming expensive, and the strength would be questionable. It would probably look like crap too.
Justice #1478871 12/14/2022 3:14 AM
K Online: Content
Maybe a option
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Justice #1478873 12/14/2022 4:36 AM
To repair that frame to make it usable might cost as much as the one that Kevinski posted.
Justice #1478876 12/14/2022 5:38 AM
If it is that bad then how thin is the rest of the frame?
Gdads51 #1478880 12/14/2022 10:57 AM
You’re right I suppose it would help if mentioned the year.
This is off a 1949 3100
Thanks for the help
Justice #1478883 12/14/2022 12:16 PM
No problem Justice!
We would all like to hear and see what you come up for your solution. Not to mention future posts about your truck and project. thumbs_up
Don't forget the pictures! grin
~ Dan
Justice #1484329 01/20/2023 3:23 PM
I had my 1960 C-10 frame repaired by a top notch frame shop. The frame was toast on both sides where the panhard bar and shocks mount. He fabbed new sections on both sides and welded them in. See pics. $1,200
