2 members (Otto Skorzeny, 5 Window 9434), 130 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#1477745 12/06/2022 3:01 AM
I had some paint mixed to paint my sun visor and artillery rims. The paint mix ratio is 3 parts paint 1 part activator 2 parts reducer. None of the measuring cups show a 3 to 1 to 2 ratio. Any ideas how to properly measure the paint?
modiol #1477752 12/06/2022 3:53 AM
3 oz. paint to 1 oz. activator to 2 oz. of reducer. OR, 3 pints of paint to 1 pint of activator to 2 pints of reducer OR etc., etc.
modiol #1477753 12/06/2022 4:01 AM
Curmudgeon
Curmudgeon
My friend, this is basic stuff you learn as a beginning novice of auto body repair.
I really don't mean to sound cruel but consider taking your parts and paint to a professional.
Mixing the paint is one task. Getting it to flow and lay nicely on the target is another.
modiol #1477765 12/06/2022 6:45 AM
What Mark said. Any combination. Like 6oz paint, 2 oz activator, and 4 oz reducer or any multiple of the mix ratio.
If you've shot paint before, you should be able to handle it.
modiol #1477768 12/06/2022 7:47 AM
Thank you for all the tips. I usually mix 4:1, which is on the measuring cup. I didn't see the ratios that I needed for this paint (single stage), I was too busy looking for the measurements on the cup and didn't even think of basic oz measurements.
modiol #1478501 12/11/2022 8:49 PM
I use the stainless “kitchen style” measuring cups. For a full gallon of paint it’s easier to dip out a cup or two than pour paint all over the side of the can. They have enough sizes to accommodate any mixing ratio. Word of caution, don’t get caught taking things out of the kitchen. grin
The paint gets dipped, anything after that is poured in so if it’s the same size, a bit of paint left on the sides won’t affect much. ie: don’t sweat cleaning between the different components if you’re using same cup.
modiol #1478637 12/12/2022 6:27 PM
A couple pieces of masking tape helps to make a no drip function.
Robert, you're not saying dip a cup used in paint into a can of hardener, are you? That would likely mess up the whole can. Not understanding what you're saying.
I have used paper cups to dip out paint to put in the mixing cup. Those get tossed after use, of course.
How's that work? Inquiring minds want to know. wink
modiol #1478653 12/12/2022 7:18 PM
I'll get a pic later. Explains it better than I can with words.
Actually, I found a Youtube video. I don't fold my ends because if they curl up, the excess will drain back to your can. Video on Youtube
modiol #1478655 12/12/2022 7:25 PM
That's pretty slick, Mark. thumbs_up
I have a couple variations of the plastic thingies that stick down to the groove in the rim, but they don't work as well as that tape trick. Paint still gets down into the groove, making putting the lid back on a mess. They're going to get tossed, and I'm using tape from now on. grin
OMG, I'm so glad that you showed us the tape trick. I just hate the loss and the mess when pouring paint out of a gallon can, especially the first pour. Thanks a lot for sharing that.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
