3 members (Nick in Manitou, CuzzFuzz, Tronman), 115 guests, and 2 robots.
Topics128,080
Posts1,056,314
Members48,442
#147839 08/07/2006 3:06 AM
I'm hoping to put power steering on my 61 GMC 5500 (it's actually a Fire Truck). Anybody know of available kits or have any suggestions?
[email protected]
Kits, probably not.
Find your parts in a junk yard and make it work, probably your best bet.
I have the power box from a 78 GMC 6500, you may want to look at one of those in your search for the one you need.
I may use it on my 48 2 ton if I ever feel like my first setup is too weak for the truck after the engine swap to Diesel.
For pictures of my swap on an AD truck click below
•1952 Chevrolet 3800 pickup
---All pictures---
Does it have an I beam front axle or independent suspension? I used a steering box from a '74 C-60 on my '66 C-60,and it fit without mods. (never hooked up the hydraulics,it drove fine without it.)Only problem I saw was the drag link was a little different length than the original,so I had to re-center the steering wheel and it turned a little sharper one way than the other. That could've been easily cured by matching the length of the newer one to the original. The set up I used had a ram that had one end attached to the tie rod with clamps and the other end connected to the center of the axle,which would require making a bracket since there's no hole for it to bolt to,the hoses would've been the right length to use as is,the set up also came with a cooler.The donor truck had a V-8 so the pump brackets wouldn't fit my 292 six,but that's not hard to cure either.
Basically an easy swap,but requires some parts searching and a little fabrication.
Don't know how much of this will be of use to you,but hope it helps.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
