3 members (Otto Skorzeny, klhansen, Bwana-Jim), 75 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#1477441 12/03/2022 8:11 PM
46 1/2 ton. What is the purpose of the shim/ wedge that goes between the front spring and axle. Thanks
That is a caster shim. It sets the caster angle of the axle in relation to the frame. Without it, when you come out of a turn, the truck will fail to automatically straighten out when you reduce force on the steering wheel as you are attempting go straight. It's absence will also result in the truck to be all over the road as you are trying to go straight without much movement of the steering wheel.
52Carl #1477447 12/03/2022 8:49 PM
Thanks for the explanation I appreciate it. So if I understand the king pin in relation to the truck/frame is at 90degs. But when it's installed to springs with the shim it give its caster angle. Is this somewhat what happens without getting to scientific.
A very unscientific (but accurate) conclusion! grin thumbs_up
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1477476 12/04/2022 12:34 AM
Great thanks for the confirmation 👍
The thicker part of the wedge goes towards the rear of the truck, incase you forget. The kingpin angle is such, that when you turn, the front of the truck raises up. It's this rise that returns the steering to center, the weight of the truck pushes the front end down and keeps it going straight.
An even more unscientific conclusion.....
Joe H #1477553 12/04/2022 10:16 PM
Perfect thanks
